Part 53. Modelling Steel Connections - 1
In this tutorial, change the locations of the elements for steel connections.
1. Hide Walls from the Filter window.
2. Switch to Full Screen in the perspective view window.
3. Open the story 1 ceiling page.
4. Select all steel columns.
5. Change the steel column rotation angle and orientation.
6. Change the column location with move command.
7. Select all steel beams.
8. Change the steel beam orientation.
9. Change the beams' node for Connecting with the steel beam nodes.
