SYMBOLS
Cd = Deflection amplification factor
Ie = Importance factor
δxe = Deflection
Deflection Amplification Factor, Cd, is defined in Table 12.2-1.
The application of the factor R/Ie to the design response spectrum reduces not only design forces but also displacements. To compensate for this, ASCE 7 requires that the deflections at level x at the center of mass, δx, be determined in accordance with where Cd is from Table 12.2-1, Ie and δxe. Using a value Cd equal to R would result in the displacement δx being equal to δxe, which would be consistent with the equal displacement rule.
Structural System Type |
Response Modification Coefficient, R |
Overstrengh Factor, Ωo |
Deflection Amplification Factor, Cd |
Structural System Limitations Including Structural Height, hn (ft) Limits |
Seismic Design Category |
B |
C |
D |
E |
F |
A. Bearing Wall Systems |
A1 - Special reinforced concrete shear walls |
5 |
21/2 |
5 |
NL |
NL |
160 |
160 |
100 |
A2 - Ordinary reinforced concrete shear walls |
4 |
21/2 |
4 |
NL |
NL |
NP |
NP |
NP |
A3 - Detailed plain concrete shear walls |
2 |
21/2 |
2 |
NL |
NP |
NP |
NP |
NP |
A4 - Ordinary plain concrete shear walls |
11/2 |
21/2 |
11/2 |
NL |
NP |
NP |
NP |
NP |
B. Building Frame Systems |
B1 - Steel eccentrically braced frames |
8 |
2 |
4 |
NL |
NL |
160 |
160 |
100 |
B2 - Steel special concentrically braced frames |
6 |
2 |
5 |
NL |
NL |
160 |
160 |
100 |
B3 - Steel ordinary concentrically braced frames |
31/4 |
2 |
31/4 |
NL |
NL |
35 |
35 |
NP |
B4 - Special reinforced concrete shear walls |
6 |
21/2 |
5 |
NL |
NL |
160 |
160 |
100 |
B5 - Ordinary reinforced concrete shear walls |
5 |
21/2 |
41/2 |
NL |
NL |
NP |
NP |
NP |
B6 - Detailed plain concrete shear walls |
2 |
21/2 |
2 |
NL |
NP |
NP |
NP |
NP |
B7 - Ordinary plain concrete shear walls |
11/2 |
21/2 |
11/2 |
NL |
NP |
NP |
NP |
NP |
C. Moment-Resisting Frame Systems |
C1 - Steel special moment frames |
8 |
3 |
51/2 |
NL |
NL |
NL |
NL |
NL |
C2 - Steel special truss moment frames |
7 |
3 |
51/2 |
NL |
NL |
160 |
100 |
NP |
C3 - Steel intermediate moment frames |
41/2 |
3 |
4 |
NL |
NL |
35 |
NP |
NP |
C4 - Steel ordinary moment frames |
31/2 |
3 |
3 |
NL |
NL |
NP |
NP |
NP |
C5 - Special reinforced concrete moment frames |
8 |
3 |
51/2 |
NL |
NL |
NL |
NL |
NL |
C6 - Intermediate reinforced concrete moment frames |
5 |
3 |
41/2 |
NL |
NL |
NP |
NP |
NP |
C7 - Ordinary reinforced concrete moment frames |
3 |
3 |
21/2 |
NL |
NP |
NP |
NP |
NP |
D. Dual Systems with Special Moment Frames Capable of Resisting at Least 25% of Prescribed Seismic Foces |
D1 - Steel eccentrically braced frames |
8 |
21/2 |
4 |
NL |
NL |
NL |
NL |
NL |
D2 - Steel special concentrically braced frames |
7 |
21/2 |
51/2 |
NL |
NL |
NL |
NL |
NL |
D3 - Special reinforced concrete shear walls |
7 |
21/2 |
51/2 |
NL |
NL |
NL |
NL |
NL |
D4 - Ordinary reinforced concrete shear walls |
6 |
21/2 |
5 |
NL |
NL |
NP |
NP |
NP |
E. Dual Systems with Intermediate Moment Frames Capable of Resisting at Least 25% of Prescribed Seismic Foces |
E1 - Steel special concentrically braced frames |
6 |
21/2 |
5 |
NL |
NL |
35 |
NP |
NP |
E2 - Special reinforced concrete shear walls |
61/2 |
21/2 |
5 |
NL |
NL |
160 |
100 |
100 |
E8 - Ordinary reinforced concrete shear walls |
51/2 |
21/2 |
41/2 |
NL |
NL |
NP |
NP |
NP |
F. Shear Wall-Frame Interactive System with Ordinary Reinforced Concrete Moment Frames And Ordinary Reinforced Concrete Shear Walls |
F1 - Shear wall-frame interactive system |
41/2 |
21/2 |
4 |
NL |
NP |
NP |
NP |
NP |
G. Cantilevered Column Systems Detailed to Conform to the Requirement for |
G1 - Steel special cantilever column systems |
21/2 |
11/4 |
21/2 |
35 |
35 |
35 |
35 |
35 |
G2 - Steel ordinary cantilever column systems |
11/4 |
11/4 |
11/4 |
35 |
35 |
NP |
NP |
NP |
G3 - Special reinforced concrete moment frames |
21/2 |
11/4 |
21/2 |
35 |
35 |
35 |
35 |
35 |
G4 - Intermediate reinforced concrete moment frames |
11/2 |
11/4 |
11/2 |
35 |
35 |
NP |
NP |
NP |
G5 - Ordinary reinforced concrete moment frames |
1 |
11/4 |
1 |
35 |
NP |
NP |
NP |
NP |
H. Steel Systems not Specifically Detailed for Seismic Resistance, Excluding Cantilever Column Systems |
H - Steel Systems not Specifically Detailed for Seismic Resistance |
3 |
3 |
3 |
NL |
NL |
NP |
NP |
NP |
