With the Beam to Shearwall command, beams are converted to shearwalls. At any stage of architectural and structural projects, the need to transform shearwalls with two columns inserted such as defined slab beams, basement perimeter shearwalls may be felt. Existing slabs and beams must be deleted in order to define a shearwall instead of a beam. With the beam to shearwall command, beams are converted to shearwalls at once without deleting slabs and beams.
Location of Beam to Shearwall Command
Click the Beam to Shearwall icon.
Select the beam or beams to be transformed into shearwalls.
The shearwall settings dialog will open.
If necessary, change the dimension or concrete material properties.
Click the OK button.
The beam will be transformed to shearwall automatically without corrupting the existing data input.
Beams to be transformed into shearwalls
Choosing the beams
Transforming beams into shearwalls
