Retaining Wall Parameters
With the Retaining Wall Parameters command, the design parameters used in the Concrete Retaining Wall Design are determined. Concrete cover, maximum and minimum reinforcement interval, etc. parameters are determined from the Retaining Wall Parameters window.
Location of Retaining Wall Parameters Dialog
Ribbon menu Analysis and Design tab Design Parameters title under Retaining Wall Parameters by clicking on the command Retaining Wall Parameters can be found in the dialogue.
It determines with parameters which criteria the program will comply with in reinforced concrete design and reinforcement placement stage.
Parameters with the ( % ) sign mean the percentage expression of the rebar ratio. It is the ratio of the cross-sectional area of ​​the reinforced concrete element to the rebar area expressed as a percentage.
Concrete cover
It is the distance from the center of gravity of the reinforcement to the outer face of the concrete.
Min. tensile percentage
In the tensile zone, give the minimum percentage value to be used in the rebar calculation. The entered value is multiplied by the sectional area and the rebar selection is made in a way that is not less than the result.
Min. tensile interval
In the tensile zone, give the smallest possible distance between two rebar bars. This value is taken into consideration in the selection of rebar.
Max. tensile interval
In the tensile zone, give the value of the greatest possible distance between two rebars. This value is taken into consideration in the selection of rebar.
Min. transverse percentage
Give the minimum percentage value to be used in horizontal rebars. The entered value is multiplied by the sectional area and the rebar selection is made in a way that is not less than the result.
Min. transverse interval
Give the smallest possible distance between two rebars for use in horizontal rebars. This value is taken into consideration in the selection of rebar.
Max. transverse interval
Give the maximum possible distance between two reinforcement bars to be used in horizontal reinforcements. This value is taken into consideration in the selection of reinforcement.
Min. compression percentage
In the pressure zone, give the minimum percentage value to be used in rebar calculation. The entered value is multiplied by the sectional area and the rebar selection is made in a way that is not less than the result.
Min. compression interval
Give the smallest possible distance between two reinforcing bars in the pressure zone. This value is taken into account in the selection of reinforcement.
Max. compression interval
Give the maximum possible distance between two reinforcing bars in the pressure zone. This value is taken into consideration in the selection of reinforcement.
