3D Block Export
With the 3D Block (Export) command in ideCAD Architectural , the 3D model of the project or project part is saved as a 3D block file as a single piece, preserving the object materials.
The 3D block (export) command is used to gather buildings defined in different projects or to import certain parts of a project into another project.
Location of Export 3D Block Command
You can access it from the menu under the ideCAD logo in the upper left corner of the ribbon menu.
  • Click the ideCAD icon/Export/3D Block icon in the ribbon menu .
  • The 3D block export dialog will appear.
  • In the dialog, switch under an appropriate folder and give a file name and click the OK button.
  • At this stage, the ideCAD will wait for the selection of objects to be saved as blocks.
  • Select the entities you want to save as blocks by clicking the entities or using the entity selection commands.
  • End the selection process by pressing the right mouse button.
  • The ideCAD will ask for a block name. Type a name in the Name line and click the OK button
  • Then, when you give the base point, the objects you selected will be transferred to the file in 3D.
Tekla.dmp Export
