It selects the elements in which the relevant section in the project are defined.
Location of Select Entities Using Section
It can be defined and changed in the Sections line under the Structure Tree.
Open the right-click menu on section.
Click the Select Entities Using Section command.
Depending on your selection, all elements in the file where this section is used will be selected.
