Creating a Jamb Profile
Primitive objects are used to create a jamb profile. By creating a closed area, a drawn section is transformed into a jamb profile object. During the transformation process, the profile object archive is opened and the section is saved there.
While defining the jamb, one of the defined sections is selected by opening the Select Profile in the Jamb Settings dialog.
Location of Transform/Polygonal Profile (Jamp) Command
  • Click one of the Primitive Object (multiple line, path, etc.) icons from the primitive toolbar or ribbon menu.
  • With the help of the coordinate system of the program, create a closed area by blocking the corner points of the section.
  • Select the lines and press the right mouse button with the cursor over the lines.
  • Click the Transform/Polygonal Profile (Jamp) line from the menu that opens .
  • The profile settings dialog will open and the prepared profile will automatically appear under the Jamb folder.
  • Give a name in the name section and click the OK button and close the dialog.
Drawing sections with primitive objects
Transform to jamb section
Naming and saving the jamb section
Profile Settings
Profile list
List of registered profile objects.
Profile preview
There is a preview of the selected closed area along with the dimensions.
Drag & drop action
Choose to copy or move to a different folder
Library management
Save the created profile section to user defined library or remove existing profile section.
Name
The profile section is named.
