Defining a Double Plate Seating Connection
With the Double Plate Seating Connection command, column-beam connection is defined.
Location of the Double Plate Seating Connection Command
  • From the Connection menu, click the Double Plate Seating Connection icon.
  • The double plate seating connection settings dialog will open.
Location of the Double Plate Seating Connection Settings Dialog
Type Tab
Type
For connection, web and dioganal plate selections are made.
Schematic drawing
Connection is shown on the schematic drawing.
Preview
Cap and Stiffener Plates Tab
Beam cap plate
The beam cap plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Beam stiffener plate
Beam stiffener plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Shim plate
Shim is a plate placed between the elements to be connected in bolted connections. If shim is to be made, the option is selected and t2, thickness value is given.
Schematic drawing
Preview
Chamfers Tab
Chamfer (c1, c2)
Schematic drawing
Preview
Connection Bolts Tab
Horizontal arrangement
Group 1
Bolt properties
Schematic drawing
Connection and bolt arrangement values ​​are shown on the schematic drawing.
Preview
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
Web Plate Tab
Web plate
The web plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Diagonal Plate Tab
Diagonal plate
The diagonal plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Design Data Tab
