How does ideCAD calculate seismic base shear according to ASCE 7-16?
The seismic base shear for each direction is calculated automatically.
Cs = The seismic response coefficient
W = The effective seismic weight
SDS = The design spectral response acceleration parameter in the short period range
R = The response modification factor in Table 12.2-1
Ie = The Importance Factor
SD1 = the design spectral response acceleration parameter at a period of 1.0 s
T = The fundamental period of the structure(s)
TL = The long-period transition period(s)
S1 = The mapped maximum considered earthquake spectral response acceleration parameter
The equivalent Lateral Force Method considered in buildings with low height can be represented by the behavior of the load-bearing system in the dominant vibration mode, and the shape of this mode can be considered as approximately the inverted triangle. Also, the procedure is valid only for structures without significant discontinuities in mass and stiffness along the height, where the dominant response to ground motions is in the horizontal direction without significant torsion.
The seismic base shear, V, in the earthquake direction considered, is determined by the following equation.
The base shear force is calculated by the above equation. The mass and Cs used in this calculation and the base shear force determined as a result of the calculation are tabulated in the Dynamic Analysis report.
The seismic response coefficient, Cs, is determined by the following equation.
The value of Cs computed with Eq. (12.8-2) need not exceed the following:
for T ≤ TL
for T > TL
Cs should not be less than
Structures located where S1 ≥ 0.6g, Cs shall not be less than
