The list of commands available in the ideCAD Architectural package program is given below in alphabetical order (Base version: 11.11)
Command |
Location of command in ribbon menu or toolbar |
Explanation |
1 |
Tools/Import-Export/Import |
Imports 3D Block. |
ideCAD logo/Import |
2 |
Tools/Import-Export/Export |
Exports 3D Block. |
ideCAD logo/Export |
3 |
Facade/Railing |
Draws 3D railing over objects. |
4 |
Facade/Railing |
Draws 3D railing. |
5 |
Rendering/3D Geometric Objects |
Draws 3d text. |
6 |
Exports to 3DS file format. |
7 |
Imports 3DS file format. |
8 |
View/Workplane/Target Workplane |
Creates a workplane through 3 points. |
9 |
Steel/Macro/Single Plate Connection |
Creates a 4 bolts stiffened end plate |
10 |
Creates a 4 bolts unstiffened end plate connection. |
11 |
Creates a 8 bolts stiffened end plate connection. |
12 |
About ideCAD Architectural |
ideCAD logo/Help |
It gives the program version and usage license information. |
13 |
Home/Snap |
Uses defined local coordinate system. |
Facade/Snap |
Concrete/Snap |
Steel/Snap |
Drawings/Snap |
14 |
Right click menu in perspective view |
Creates snap points on a line in a perspective image. |
15 |
It is located in the trim to roof toolbar. |
Adds new entities to the trim group. |
16 |
It is located in the hatch toolbar. |
Adds lines to the hatch edges. |
17 |
Add a new point to hatch. |
18 |
Adds roof to the trim group. |
19 |
Home/Concrete/Stair |
Adds stair area to an existing stair. |
Concrete/Concrete/Stair |
20 |
Right click menu |
Adds new objects to the groups |
21 |
Modify/Entity Edit/Dimension |
Adds/removes dimension parents. |
22 |
Home/Edit |
Generates array of entities. |
Facade/Edit |
Concrete/Edit |
Steel/Edit |
Drawings/Edit |
23 |
Home/Snap |
Enables advanced snap mode. |
Facade/Snap |
Concrete/Snap |
Steel/Snap |
Drawings/Snap |
24 |
Settings/Menu Settings |
Edits commands used on the command line. |
25 |
It is located in the align toolbar. |
Aligns the selected entities at the bottom. |
26 |
Aligns the selected entities by drawing a path. |
27 |
Align the selected entities by selecting an edge of entity. |
28 |
Home/Modify |
Aligns the selected entities. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
29 |
Aligns the selected entities to the left. |
30 |
Aligns the selected entities to the object center. |
31 |
Aligns the selected entities to the nearest point. |
32 |
Aligns the selected entities to the right. |
33 |
Aligns the selected entities to the top. |
34 |
Home/Reference |
Measures the angle. |
Facade/Reference |
Concrete/Reference |
Steel/Reference |
Tools/Reference |
Drawings/Reference |
35 |
Drawings/Dimension |
Draws angle dimension. |
36 |
Drawings/Dimensions/Level Dimension |
Opens angle dimension settings. |
37 |
It is located in the library toolbar. |
Sets vertical angle of library automatically using underlying geometry. |
38 |
Creates a apex type connection. |
39 |
It is located in the primitives toolbar. |
Draws arc. |
40 |
Home/Axis |
Draws arc axis. |
Concrete/Axis |
Steel/Axis |
41 |
Home/Axis |
Draws arc axis through 3 points. |
Concrete/Axis |
Steel/Axis |
42 |
Concrete/Concrete |
Draws arc beam. |
43 |
Home/Roof/Dome |
Draws arc dome. |
44 |
Home/Roof/Dome |
Draws arc dome through 3 points. |
45 |
Concrete/Concrete/Slab Edge |
Draws arc slab edge. |
46 |
Draws arc through 3 points. |
47 |
It is located in the wall toolbar. |
Draws arc wall. |
48 |
It is located in the zone edge toolbar. |
Draws arc zone edge. |
49 |
Home/Reference |
Calculates area. |
Facade/Reference |
Steel/Reference |
Tools/Reference |
50 |
Home/Edit |
Generates an array of entities. |
Facade/Edit |
Concrete/Edit |
Steel/Edit |
Drawings/Edit |
51 |
Rendering/Render |
Continously assigns selected material to face groups. |
52 |
Modify/Entity Edit |
Auto label entities. |
Tools/Tools |
53 |
Creates hatch with closed polygons. |
54 |
Home/Axis |
Draws axis. |
Concrete/Axis |
Steel/Axis |
55 |
Modify/Entity Edit/Move Axis Label |
Sets the axis border. |
56 |
It is located in the axis toolbar. |
Draws an axis with an offset to the previous axis drawn. |
57 |
Home/Axis/Axis |
Opens axis settings. |
Concrete/Axis/Axis |
Steel/Axis/Axis |
58 |
View/Perspective |
Changes view to axonometric. |
59 |
View/Perspective |
Changes view to back. |
60 |
View/View |
Opens background settings. |
61 |
It is located in the sweep toolbar. |
Draws baseboard. |
62 |
Concrete/Concrete |
Draws multiple beams. |
63 |
Concrete/Concrete/Beam |
Opens beam settings. |
64 |
Modify/Transform |
Converts beams to shearwalls. |
65 |
Facade/Exterior Facade/Curtain Wall |
Bends curtain wall. |
66 |
Drawings/Primitives/NURBS |
Draws bezier curve. |
67 |
Drawings/Hatch |
Draws bitmap hatch. |
68 |
Creates a bolted flange plate connection. |
69 |
Draws border on wall. |
70 |
Home/Roof/Vault |
Draws border vault. |
71 |
View/Perspective |
Changes view to bottom. |
72 |
Home/Entities/3D Objects |
Draws box. |
Facade/3D Geometric Objects/3D Objects |
73 |
Creates box/tube cap plate. |
74 |
Creates a box/tube end plate connection. |
75 |
Creates a box/tube seating connection. |
76 |
Creates a box/tube splice connection. |
77 |
Creates a brace center connection(9). |
78 |
Creates a brace corner connection(10). |
79 |
Home/Modify |
Breaks off a certain part of the objects. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
80 |
Tools/BUA/FAR Reports |
Creates GRZ/GFZ report. |
81 |
Home/Axis/Axis |
Calculates contour polygon. |
Steel/Axis/Axis |
82 |
Rendering/Lights-Camera |
Draws camera. |
83 |
Rendering/Render |
Creates camera animaton. |
84 |
Rendering/Render |
Draws camera path. |
85 |
Rendering/Lights-Camera/Camera |
Opens camera settings. |
86 |
Modify/Entity Edit/Stair |
Cancels secondary stair deformation. |
87 |
Cancels stair deformations. |
88 |
Draws ceiling cornice. |
89 |
It is located in the column toolbar. |
Sets center aligned. |
90 |
It is located in the single footing toolbar. |
Sets centered single footing. |
91 |
Home/Modify |
Connects two lines with a third line. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
92 |
Home/Axis |
Changes axis drawing type. |
Concrete/Axis |
Steel/Axis |
93 |
Changes baluster count. |
94 |
Modify/Entity Edit/Column |
Changes column dimensions. |
95 |
It is located in the ODT door/window toolbar. |
Change dio distance point. |
96 |
Modify/Entity Edit/Sweep |
Change edge part end angles. |
97 |
Modify/Layers |
Changes layers of selected entities. |
98 |
It is located in the jamb toolbar. |
Changes jamb placement to the other side of dio. |
99 |
Right click menu in plan view. |
100 |
Home/Roof/Roof |
Changes rafter dimensions. |
Modify/Entity Edit/Roof |
101 |
Home/Roof/Roof Details |
Changes roof edge properties. |
102 |
Home/Concrete/Shearwall |
Changes shearwall length. |
103 |
It is located in the railing toolbar. |
Changes path direction. |
It is located in the curtain wall toolbar. |
104 |
ideCAD logo/Help |
Check for updates. |
105 |
Tools/Tools |
Checks validity of project geometry. |
106 |
Drawings/Primitives |
Draws circle. |
107 |
Draws circle beam. |
108 |
Concrete/Concrete Slab Edge |
Draws circle slab edge. |
109 |
Draws circle walls. |
110 |
Draws circle zone edge. |
111 |
Home/Concrete/Column |
Draws circular column. |
Concrete/Concrete |
112 |
Modify/Transform/Beam to Shearwall |
Converts circular columns to rectangular columns. |
Right click menu |
113 |
Home/Edit |
Clones (immediately copies) objects. |
Facade/Edit |
Concrete/Edit |
Steel/Edit |
Drawings/Edit |
114 |
Close |
ideCAD logo |
Closes current project. |
115 |
Draws closed bezier curve. |
116 |
Right Click Menu |
Closes the layer of the object. |
117 |
Draws closed NURBS curve. |
118 |
Transforms primitive entities to polygon column. |
119 |
Transforms primitive entities to polygon section. |
120 |
Draws a collar beam. |
121 |
Home/Concrete |
Draws rectangular column. |
Concrete/Concrete |
122 |
Opens column settings. |
Concrete/Concrete/Column |
123 |
Draws column support. |
Concrete/Concrete |
124 |
Converts columns to shearwalls. |
Right click menu |
125 |
Creates a column-beam stiffened end plate connection. |
126 |
Creates a built up column connection. |
127 |
Creates a column-column end plate splice connection. |
128 |
Creates a column-foundation connection (Stiffened baseplate). |
129 |
Tools/Quantity Report |
Creates components report. |
130 |
Settings/Element Materials |
Constructs and arranges composite materials. |
131 |
Steel/Steel |
Draws composite slab. |
132 |
Steel/Steel/Composite Slab |
Draws composite solid slab. |
133 |
Draws concrete slab over steel beams. |
134 |
It is located in the tubes toolbar. |
Draws cone-pyramid. |
135 |
Contents |
ideCAD logo/Help |
Opens the program's help document. |
136 |
Concrete/Concrete |
Draws continuous arc beams. |
137 |
Home/Wall |
Draws continuous arc walls. |
138 |
Creates a continuous beam connection. |
139 |
Draws continuous slab edges. |
140 |
Draws continuous zone edges. |
141 |
Home/Axis/Axis |
Sets contours of the drawing. |
Steel/Axis/Axis |
142 |
Home/Edit |
Copies entities. |
Facade/Edit |
Concrete/Edit |
Steel/Edit |
Drawings/Edit |
143 |
Tools/Edit |
Copies contours of a drawing. |
144 |
Tools/File Sharing |
Copies entities to a .blk file. |
145 |
Facade/3D Geometric Objects |
Draws cordon. |
146 |
Facade/3D Geometric Objects/Cordon |
Opens cordon settings. |
147 |
Sets corner aligned column. |
148 |
Sets corner aligned single footing. |
149 |
Steel/Macro |
Draws crane. |
150 |
Creates a crane connection. |
151 |
Right click menu in the perspective view |
Creates camera. |
152 |
View/Workplane |
Creates a clip plane. |
153 |
Drawings/Layout Design |
Creates a new layout window. |
154 |
Right click menu |
Creates new selection groups. |
155 |
Creates a new stair. |
156 |
Creates user defined hatch from block objects. |
157 |
Facade/Exterior Facade |
Draws curtain wall. |
158 |
Draws curtain wall dio. |
159 |
Opens curtain wall settings. |
160 |
Concrete/Concrete |
Draws curve beam. |
161 |
Draws curve slab edge. |
162 |
Home/Wall |
Draws curve wall. |
163 |
Draws curve zone edge. |
164 |
Converts circle, arc, ellipse objects to beam. |
165 |
Converts circle, arc, ellipse objects to shearwall. |
166 |
Converts circle, arc, ellipse objects to wall. |
167 |
Right-click on any point of the vertical toolbar |
Customize the vertical toolbar and the customizable toolbar on the top edge. |
168 |
Draws cylinder. |
169 |
Creates DIN277 report. |
170 |
Imports DWG DXF file formats. |
171 |
Exports to DWG DXF DWF file formats. |
172 |
172 |
Sets default aligned. |
173 |
Sets default single footing. |
174 |
Home/Snap |
Defines temporary coordinate system origin. |
Facade/Snap |
Concrete/Snap |
Steel/Snap |
Drawings/Snap |
175 |
Defines end cut to edge. |
176 |
Defines inner cut to edge. |
177 |
Defines local offset to edge. |
178 |
Defines offset to edge. |
179 |
Deforms stair. |
180 |
Home/Edit |
Delete entities. |
Facade/Edit |
Concrete/Edit |
Steel/Edit |
Drawings/Edit |
181 |
Deletes trim group. |
182 |
It is located in the horizontal plan section toolbar. |
Deletes horizonal plan section. |
183 |
It is located in the mirror toolbar. |
Delete old entities on mirror. |
184 |
It is located in the pool toolbar. |
Delete primitives after pool creation. |
185 |
Deletes roof element(s). |
186 |
It is located in the slab for steels toolbar. |
Deletes slab hole. |
187 |
Changes delta value. |
It is located in the beam toolbar. |
It is located in the shearwall toolbar. |
It is located in the strip footing toolbar. |
188 |
Home/Edit |
Deselects all entities. |
Facade/Edit |
Concrete/Edit |
Steel/Edit |
Drawings/Edit |
189 |
Design components. |
190 |
Draws directional light. |
191 |
Rendering/Lights-Camera/Directional Light |
Directional light settings. |
192 |
View/Workplane |
Display a vertical frame. |
193 |
Home/Reference |
Calculates distance. |
Facade/Reference |
Steel/Reference |
Tools/Reference |
194 |
It is located in the distribute toolbar. |
Distribute by drawing a path. |
195 |
Distribute by selecting an edge of entity. |
196 |
Home/Modify |
Distrubutes the selected entities. |
197 |
Distrubutes selected entities to the horizontally. |
198 |
Distribute selected entities to the object center. |
199 |
Distribute selected entities to the nearest point. |
200 |
Distrubute selected entities to the vertically. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
201 |
Home/Modify |
Divides the objects to the desired number. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
202 |
Steel/Steel/Steel Purlin |
Divides and combines on all intersections. |
203 |
Divides and combines on selected intersections. |
204 |
Home/Roof |
Draws dome. |
205 |
Facade/3D Geometric Object |
Draws dome gutter. |
206 |
Facade/3D Geometric Object/Dome Gutter |
Opens dome gutter settings. |
207 |
Home/Roof/Dome |
Opens dome settings. |
208 |
Home/Door-Window/Door-Window |
Opens door/Window settings. |
Facade/Door-Window/Door-Window |
209 |
Home/Door-Window |
Draws Door/Window. |
Facade/Door-Window |
210 |
Home/Roof |
Draws dormer. |
211 |
Home/Door-Window |
Draws dormer window. |
Home/Roof/Dormer |
212 |
Home/Roof/Dormer |
Opens dormer settings. |
213 |
Creates a double angle connection. |
214 |
Creates a double plate seating connection. |
215 |
Steel/Macro/Truss |
Draws Double Vault Truss. |
216 |
Tools/Tools |
Enters drafting mode. |
217 |
View/View |
Draw line weights. |
218 |
Steel/Macro |
Draws connection in fast mode. |
219 |
Right click menu |
Draws similar entity of the selected one. |
220 |
It is located in the steel brace toolbar. |
Draws single steel brace. |
221 |
Draws slab hole. |
222 |
Draws steel brace elements. |
223 |
Draws steel brace with multiple steel elements. |
224 |
View/Window |
Display drawing list. |
Drawings/Window |
225 |
View/Window |
Arrange drawings in the project. |
226 |
Home/Door-Window |
227 |
Creates a eaves haunch connection. |
228 |
Sets edge aligned single footing. |
229 |
Edits curtain wall item. |
230 |
It is located in the ODT Door/Window toolbar. |
Edits door/window angle. |
231 |
Edit label text. |
232 |
Rendering/Render |
Edits material of an object. |
233 |
Home/Entities/Railing |
Edits railing elevations. |
Facade/Railing/Railing |
234 |
Edit slab edge. |
235 |
Edit stair. |
236 |
Rendering/Render |
Edits surface mapping parameters. |
237 |
Edit text. |
Drawings/Text |
238 |
Modify/Entity Edit/Wall |
Edit walls. |
239 |
Home/Terrain/Terrain Polygon |
Draws elevation line for terrain. |
240 |
Drawings/Tools |
Draws elevation line for elevation. |
241 |
Drawings/Tools/Elevation Line |
Elevation line settings. |
242 |
Draws elevation point. |
243 |
Drawings/Primitives/Ellipse Corners |
Draws ellipse using center and corner. |
244 |
Draws ellipse using corner. |
245 |
Draws ellipse using midpoint and axis. |
246 |
Draws elliptical arc using center and corner. |
247 |
Draws elliptical arc using corners. |
248 |
Draws elliptical arc using midpoint and axis. |
249 |
Creates an end plate shear connection. |
250 |
Creates an end plate truss connection. |
251 |
Creates an end plate truss connection for box/tube. |
252 |
Keyboard |
Runs the command. It has functions in various command stages. |
253 |
Tools/Generate |
Entity from primitives. |
254 |
Home/Modify |
Changes entity properties. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Modify/Entities |
Drawings/Modify |
255 |
Keyboard |
Exits the found command. |
256 |
Exchange coordinates. |
257 |
Exit |
ideCAD logo |
Quits the application. |
258 |
Home/Modify |
Separates the blocks into sub-blocks. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
259 |
Explodes roof. |
260 |
It is located in the steel beam toolbar. |
Explodes and groups multi-element entities into single elements. |
It is located in the steel purlin toolbar. |
261 |
Tools/Quantity Report/Export |
Exports components as a database file To AMP. |
262 |
Exports components as a database file To OSKA. |
263 |
Home/Modify |
Line extends primitive objects such as arcs to another line or arc. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
264 |
Draws exterior veneer. |
265 |
Facade/Exterior Facade/Exterior Veneer |
Exterior veneer settings. |
266 |
Draws extruded object. |
267 |
Draws fascia boards. |
268 |
Home/Modify |
Activates fast move. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
269 |
Home/Modify |
It connects two lines with an arc. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
270 |
Tools/Tools |
Finds entities based on their labels and change the labels. |
271 |
Finds hatch holes. |
272 |
Finds the selected object which is in the plan window, in the perspective window and zooms the view to that object. |
273 |
Right click menu in plan view |
Finds the selected object which is in the perspective window, in the plan window and zooms the view to that object. |
274 |
Creates a flange plate connection. |
275 |
Steel/Macro/Truss |
Draws Flat Truss. |
276 |
Opens fly mode. |
277 |
Drawings/Text |
Draws formatted text. |
278 |
Draws free dimension. |
279 |
Drawings/Dimensions/Free Dimension |
Opens free dimension settings. |
280 |
Sets free drawn. |
281 |
Draws freehand curve. |
282 |
Concrete/Concrete/Slab |
Creates a free mode slab by selecting boundary entities manually. |
283 |
Home/Zone/Zone |
Creates a free mode zone by selecting boundary entities manually. |
284 |
View/Perspective |
Changes view to front. |
285 |
Sweep settings. |
286 |
Tools/Generate |
Generates a 2D simple drawing using current drawing. |
Drawings/Tools |
287 |
Tools/Generate |
Generates vector drawing. |
Rendering/Tools |
288 |
It is located in the terrain toolbar. |
Get elevation from terrain. |
289 |
Home/Modify |
Picks settings from entity. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Modify/Entities |
Drawings/Modify |
290 |
Tools/Selection Groups |
Gets currently selected entities. |
291 |
Creates a girt connection. |
292 |
View/View |
Grid & limits settings. |
293 |
Groups selected entities and selects entities based on these groups. |
294 |
Steel/Macro |
Creates hall. |
295 |
Steel/Macro/Hall |
Opens the hall settings. |
296 |
Steel/Macro |
Creates steel hand rail. |
297 |
Steel/Macro/Hand Rail |
Opens the hand rail settings. |
298 |
Drawings/Hatch |
Draws hatch hole. |
299 |
Drawings/Hatch/User Defined Hatch |
Hatch settings. |
300 |
Creates a haunch connection. |
301 |
View/View/Solid with Edges |
Changes view detail to hidden line. |
302 |
View/View |
Changes view detail to hidden line black && white. |
303 |
Right click menu |
Removes all selected entities in the 3D view. |
304 |
Hides/shows edge. |
305 |
Hides/shows edge part. |
306 |
Draws hip/valley rafters. |
307 |
Home/Terrain |
Draws hole. |
308 |
Rendering/Tools |
Opens horizontal plan section toolbar. |
309 |
Creates a horizontal workplane. |
310 |
Imports IFC file. Merges file content with current project. |
311 |
Exports project to IFC. |
312 |
Creates II BV report. |
313 |
Drawings/Text |
Imports text from a text file. |
314 |
Right click menu/Drawing order |
Sends the selected object to the background. |
315 |
Sends the selected object behind a certain object. |
316 |
Sends the selected object to the foreground. |
317 |
Sends the selected object in front of a certain object. |
318 |
Incline objects. |
319 |
It is located in the dimension toolbar. |
Includes beams into section dimension. |
320 |
Includes doors/windows into section dimension. |
321 |
Includes slabs into section dimension. |
322 |
Drawings/Dimensions |
Draws inner dimension. |
323 |
Opens inner dimension settings. |
324 |
Settings/Project Settings |
Opens input units. |
325 |
Drawings/Layout Design/Create New Layout |
Inserts a layout block. |
326 |
Changes insertion point. |
It is located in the stair toolbar. |
327 |
Draws intersection dimension. |
328 |
Home/Edit |
Inverts current selection. |
Facade/Edit |
Concrete/Edit |
Steel/Edit |
Drawings/Edit |
329 |
ideCAD Home |
ideCAD logo |
Opens the start page. |
330 |
Draws jamb. |
331 |
Facade/Exterior Veneer/Jamb |
Opens jamb settings. |
332 |
Home/Modify |
Joins linear objects. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
333 |
Creates a beam-beam connection (Joining plates). |
334 |
Coordinate Box |
L enters the coordinate box. Object length is entered. |
335 |
Draws label. |
336 |
Label entities. |
337 |
It is located in the exterior veneer toolbar. |
Draws lap siding. |
338 |
Draws lap siding with gap. |
339 |
Home/Edit |
Selects last selected entities. |
Facade/Edit |
Concrete/Edit |
Steel/Edit |
Drawings/Edit |
340 |
Draws laths. |
341 |
Settings/Element Properties |
Opens layer settings. |
342 |
Right click menu on the plan view. |
343 |
Changes settings of current layout. |
344 |
View/Perspective |
Changes view to left. |
345 |
Sets edge left middle aligned. |
346 |
Left side section dimension. |
347 |
Draws level dimension. |
348 |
Opens level dimension settings. |
349 |
Home/Entities |
Draws library. |
350 |
Home/Entities/Library |
Draws library settings. |
Rendering/3D Geometric Objects/Library |
Drawings/Primitives/Library |
351 |
Loads settings from a file. |
352 |
Tools/Edit |
Local undo, undo for current mode only. |
353 |
Modify/Layers |
Locks/Unlocks layers. |
354 |
Right Click Menu |
Lock the layer of the object. |
355 |
Home/Modify |
Blocks entities. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
356 |
Tools/Edit |
Make architectural file compatible with structural. |
357 |
Materials are listed, edited, created. |
Rendering/Render |
358 |
Opens menu settings. |
359 |
Draws metal slab. |
360 |
Home/Snap |
Snaps to midpoints of entities. |
Facade/Snap |
Concrete/Snap |
Steel/Snap |
Drawings/Snap |
361 |
Home/Modify |
Takes symmetry. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
362 |
Mirrors door/window labels. |
363 |
Takes symmetry with respect to the X-axis. |
364 |
Takes symmetry with respect to the Y-axis. |
365 |
It is located in the trusses toolbar. |
Allow modify sub elements of truss. |
366 |
Home/Modify |
Move. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
367 |
Home/Axis/Axis |
Moves axis label. |
Steel/Axis/Axis |
Modift/Entity Edit |
368 |
Moves dimension texts. |
369 |
It is located in the raft foundation toolbar. |
Moves raft foundation text. |
370 |
Modify/Entity Edit/Slab |
Moves slab text. |
371 |
Home/Door-Window/Stair |
Moves stair text. |
372 |
Modify/Entity Edit/Zone |
Moves zone text. |
373 |
Creates multi stiffener plates. |
374 |
Creates horizontal multi stiffener plates. |
375 |
Draws multiple lines. |
376 |
Home/Snap |
Snaps to nearest points of entities. |
Facade/Snap |
Concrete/Snap |
Steel/Snap |
Drawings/Snap |
377 |
ideCAD logo |
Opens the new project open dialog. |
378 |
ideCAD logo |
Creates a new, empty 2D drawing window. |
379 |
Adds new horizontal plan sections. |
380 |
ideCAD logo |
Creates a new project. |
381 |
Creates a new layout block using all drawing. |
382 |
Creates a new layout block |
383 |
384 |
385 |
386 |
Add new trim group. |
387 |
View/Window |
Activates next window. |
388 |
View/Nodes |
Opens node settings. |
389 |
Creates a notched seating connection. |
390 |
Draws NURBS curve. |
391 |
Home/Modify |
Offset. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
392 |
It is located in the section toolbar. |
Finishes the current job. |
393 |
ideCAD logo |
Opens a previously saved project. |
394 |
Home/Snap |
Enters orthogonal drawing mode. |
Facade/Snap |
Concrete/Snap |
Steel/Snap |
Drawings/Snap |
395 |
Draws outer dimension. |
396 |
Opens outer dimension settings. |
397 |
Keyboard |
Scrolls down the page in reports. Also shifts the viewpoint down in fly mode in the perspective view. |
398 |
Keyboard |
Scrolls the page up in reports. Also shifts the viewpoint upwards in flight mode in the perspective view. |
399 |
View/Zoom |
Pans the window. |
400 |
Home/Snap |
Parallel reference. |
Facade/Snap |
Concrete/Snap |
Steel/Snap |
Drawings/Snap |
401 |
Home/Edit |
Paste entities. |
Facade/Edit |
Concrete/Edit |
Steel/Edit |
Drawings/Edit |
402 |
Draws path primitives. |
403 |
Sets path based. |
404 |
Draws pattern path. |
405 |
Drawings/Hatch |
Draws parametric hatch. |
406 |
Sets parent based. |
407 |
Tools/Edit |
Pastes contours. |
408 |
Pastes entities from a .blk file. |
409 |
Exports To PDF. |
410 |
Opens pen and color settings. |
411 |
Home/Snap |
Perpendicular reference. |
Facade/Snap |
Concrete/Snap |
Steel/Snap |
Drawings/Snap |
412 |
View/Perspective |
Changes view to perspective. |
413 |
Draws photometric light. |
414 |
Rendering/Lights-Camera/Photometric Light |
Photometric light settings. |
415 |
Saves the screen image as a bitmap file. |
416 |
Rendering/Render |
Creates Planar Texutre Mapper Object. |
417 |
Home/Terrain |
Draws plateau. |
418 |
ideCAD logo |
Plots your drawings. |
419 |
Draws point light. |
420 |
Rendering/Lights-Camera/Point Light |
Point light settings. |
421 |
Home/Edit |
Creates copies of objects with rotation. |
Facade/Edit |
Concrete/Edit |
Steel/Edit |
Drawings/Edit |
422 |
Polar tracking. |
423 |
Draws polygon column. |
Concrete/Concrete |
424 |
Transforms primitive entities to plate section. |
425 |
Steel/Steel/Sheeting |
Draws sheeting polygon. |
426 |
Home/Entities |
Draws pool. |
427 |
Home/Entities/Pool |
Opens pool settings. |
428 |
Draws a post. |
429 |
Home/Project Settings |
Opens preferences. |
430 |
View/Window |
Activates previous window. |
431 |
Opens profiles |
432 |
Open project settings. |
433 |
Open project save settings. |
434 |
Opens project settings. |
Concrete/Project Settings |
Steel/Project Settings |
435 |
Draws purlins. |
436 |
Creates a purlin connection. |
437 |
Creates stiffener plates. |
438 |
Generates a report of quantities in the project. |
439 |
Draws R purlin. |
440 |
Draws radius dimension. |
441 |
Opens radius dimension settings. |
442 |
Concrete/Foundation |
Draws raft foundation. |
443 |
Draws raft edge. |
444 |
Concrete/Foundation/Raft Edge |
Opens raft edge settings. |
445 |
Concrete/Foundation/Raft |
Draws raft foundation hole. |
446 |
Opens raft foundation settings. |
447 |
Draws rafters. |
448 |
Home/Entities |
Draws railing. |
Facade/Railing |
449 |
Draws 3D railing. |
450 |
451 |
Opens railing settings. |
FacadeRailing/Railing |
452 |
Home/Roof |
Draws rainwater pipe. |
453 |
Home/Roof/Rainwater Pipe |
Opens rainwater pipe settings. |
454 |
Places a raster image file onto the drawing. |
455 |
Rendering/Render |
Recalls render with the last settings. |
456 |
Drawings/Primitives/Multiple Lines |
Draws a rectangle. |
537 |
Converts rectangular columns to circular columns. |
Right click menu |
458 |
Home/Wall |
Draws 4walls as a rectangle. |
459 |
Tools/Edit |
Redo. |
460 |
Removes end cut of edge. |
461 |
Right click menu |
Removes objects from the group. |
462 |
Removes inner cut of edge. |
463 |
Removes local offset of edge. |
464 |
It is located in the space truss toolbar. |
Removes a nodule from space truss. |
465 |
Removes offset of edge. |
466 |
Removes an existing point on the hatch. |
467 |
Rendering/Render |
Renders active view. |
468 |
Resets dimension text displacements. |
469 |
Resets settings. |
470 |
Draws revision cloud. |
471 |
Draws revolved object. |
472 |
View/Perspective |
Changes view to right. |
473 |
Right side section dimension. |
474 |
Creates a rigid on both axis base plate connection. |
475 |
Creates a rigid on strong axis base plate connection. |
476 |
Home/Roof |
Draws roof. |
477 |
It is located in the roof toolbar. |
Opens the roof details toolbar. |
478 |
Draws roof gutter. |
479 |
Facade/3D Geometric Object/Roof Gutter |
Opens roof gutter settings. |
480 |
Home/Roof/Roof |
Draws roof hole. |
481 |
Home/Roof/Roof |
Draws roof plane. |
482 |
Home/Roof/Roof |
Opens roof settings. |
483 |
Home/Door-Window |
Draws roof window. |
Home/Roof/Roof |
484 |
Home/Modify |
Rotate. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
485 |
Home/Modify |
Rotates the building. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Tools/Tools |
Drawings/Modify |
486 |
Facade/Exterior Veneer/Curtain Wall |
Rotates curtain wall panel. |
487 |
Home/Modify |
Rotates node. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
488 |
Creates a round plate tube base plate connection. |
489 |
ideCAD logo |
Saves current project. |
490 |
ideCAD logo |
Save current project with a new name. |
491 |
ideCAD logo |
Saves compresed project file. |
492 |
ideCAD logo |
Saves old version project file. |
493 |
Save Screen Image |
ideCAD logo |
494 |
Saves settings to a file. |
495 |
Saves stair. |
496 |
Home/Modify |
Scales entities. |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
497 |
Home/Modify |
Scales entities by referance. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
498 |
Creates a seating support connection(8). |
499 |
Creates a seating truss connection. |
500 |
Creates a seating weld connection. |
501 |
Secondary stair deformation. |
502 |
Steel/Steel |
Draws secondary beam. |
503 |
Tools/Generate |
Edit and generate sections and elevations. |
Drawings/Tools |
504 |
Draws single section dimension. |
505 |
Draws section dimension group. |
506 |
Draws section elevation. |
507 |
Drawings/Tools |
Opens section elevation settings. |
508 |
Drawings/Tools |
Draws section line. |
509 |
Drawings/Tools/Section Line |
Opens section line settings. |
510 |
Home/Edit |
Selects all entitites. |
Facade/Edit |
Concrete/Edit |
Steel/Edit |
Drawings/Edit |
511 |
Select purlins to add analysis. |
512 |
Home/Edit |
Selects entity in all stories. |
Facade/Edit |
Concrete/Edit |
Steel/Edit |
Drawings/Edit |
513 |
Right click menu |
Select the objects in the group. |
514 |
Selects terrain and child entities. |
515 |
Set auto elevation. |
516 |
Home/Modify |
Sets default settings to selected entities. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Modify/Entities |
Drawings/Modify |
517 |
Sets hatch reference point. |
518 |
Home/Snap |
Sets new local coordinate system. |
Facade/Snap |
Concrete/Snap |
Steel/Snap |
Drawings/Snap |
519 |
Set pool cantilever slab properties. |
Modify/Entity Edit/Pool |
520 |
Set pool surface properties. |
521 |
Set pool surface slope. |
522 |
Set pool wall properties. |
523 |
Sets currently selected entities. |
524 |
It is located in the steel column toolbar. |
Sets steel element delta. |
525 |
Sets entity trim algorithm. |
526 |
Sets priorities of wall at joints. |
527 |
Home/Concrete |
Draws shearwall. |
Concrete/Concrete |
528 |
Opens shearwall settings. |
Concrete/Concrete/Shearwall |
529 |
Converts shearwalls to beams. |
530 |
Converts shearwalls to columns. |
Right click menu |
531 |
Steel/Steel |
Draws sheeting over purlins. |
532 |
Draws sheeting between two elements. |
533 |
View/View |
Show coordinate box. |
534 |
Right click menu in the perspective view. |
Shows the render boundaries before rendering. |
535 |
View/View |
Show toolbars. |
536 |
Shows/hides dimension text. |
537 |
Modify/Layers |
Show/hide entity layers. |
538 |
View/Nodes |
Shows/hides nodes |
539 |
Shows/hides railings. |
540 |
Creates a simple base plate connection. |
541 |
Draws single footing. |
542 |
Creates a single angle connection. |
543 |
Concrete/Foundation/Single |
Opens single footing settings. |
544 |
Creates a single plate connection. |
545 |
Creates a single plate seating connection. |
546 |
Draws single steel purlin. |
547 |
Draws single secondary beam. |
548 |
Concrete/Concrete |
Draws slab. |
549 |
Concrete/Concrete |
Draws slab edge. |
550 |
Draws steel slab edge. |
551 |
Opens slab edge settings. |
552 |
Draws slab hole. |
553 |
Opens slab settings. |
554 |
Steel/Macro/Truss |
Draws Sloping Flat Truss. |
555 |
Steel/Macro/Truss |
Draws Sloping Vault Truss. |
556 |
Home/Snap |
Snap to grid. |
Facade/Snap |
Concrete/Snap |
Steel/Snap |
Drawings/Snap |
557 |
Home/Snap |
Snap to nodes. |
Facade/Snap |
Concrete/Snap |
Steel/Snap |
Drawings/Snap |
558 |
View/View |
Changes view detail to solid. |
559 |
View/View |
Changes view detail to solid with edges. |
560 |
Keyboard |
Moves the cursor to horizontal, vertical, and free axis drawing positions on axes. Changes the offset in commands such as wall, column, beam, shearwall. Skips a name in object labeling. Changes the insertion point in commands such as stair, library. |
561 |
Draws space purlin. |
562 |
Steel/Macro |
Draws space truss. |
563 |
Creates a spacer plate connection. |
564 |
Draws sphere. |
565 |
Creates a splice connection. |
566 |
Draws spotlight. |
567 |
Rendering/Lights-Camera/Spot Light |
Opens spot light settings. |
568 |
Home/Concrete |
Draws stair. |
Concrete/Concrete |
569 |
Steel/Macro |
Creates steel stair. |
570 |
Steel/Macro/Stair |
Opens the steel stair settings. |
571 |
Opens stair settings. |
572 |
Creates a stay connection. |
573 |
Craetes a stay connection (secondary beam). |
574 |
Steel/Steel |
Draws steel beam. |
575 |
Steel/Steel |
Draws steel brace. |
576 |
Steel/Steel |
Draws steel column. |
577 |
It is located in th steel column toolbar. |
578 |
Creates steel hand rail on arc. |
579 |
Creates steel hand rail on line. |
580 |
Steel/Steel |
Draws steel purlin. |
581 |
Draws steel tie. |
582 |
Creates a stiffened end plate connection. |
583 |
Creates a stiffened shear plate connection. |
584 |
Arrange stories in the project. |
585 |
Sets story alignment free. |
586 |
Sets story bottom aligned. |
587 |
Copies all entities from a story to another story. |
Tools/Edit |
588 |
Opens story list. |
View/Window |
Drawings/Window |
589 |
590 |
Sets story top aligned. |
591 |
Home/Modify |
Stretch node. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
592 |
Draws multiple strip footings. |
593 |
Concrete/Foundation/Strip |
Opens strip footing settings. |
594 |
View/Mode |
Enters structural design mode. |
595 |
Draws a strut. |
596 |
Creates stub. |
597 |
Home/Terrain |
Draws sub region. |
598 |
Swaps side. |
599 |
Draws sweep. |
600 |
Opens the sweep operations toolbar. |
601 |
Drawings/Window |
Returns to last story window. |
602 |
Creates a T plate connection. |
603 |
Home/Snap |
Draws tangents. |
Facade/Snap |
Concrete/Snap |
Steel/Snap |
Drawings/Snap |
604 |
View/Workplane |
Creates a free workplane using existing objects. |
605 |
Draws terra cotta siding. |
606 |
Home/Terrain |
Draws terrain polygon. |
607 |
Opens terrain settings. |
608 |
Rendering/3D Geometric Objects/3D Text |
Draws text. |
Drawings/Text |
609 |
Opens font settings. |
Drawings/Text/Text |
610 |
Tip of the Day |
ideCAD logo/Help |
Shows tip of the day. |
611 |
Right click menu |
Switches between perspective and axonometric views. |
612 |
View/Window |
Resizes the view to full screen. |
613 |
View/Perspective |
614 |
Transforms a slab to a ribbed slab. |
615 |
Transforms a slab to a waffle slab. |
616 |
View/View |
Opens transparent story settings dialog. |
617 |
Steel/Macro/Truss |
Draws Trapezoid Sloping Left Truss. |
618 |
Steel/Macro/Truss |
Draws Trapezoid Sloping Right Truss. |
619 |
Steel/Macro/Truss |
Draws Trapezoid Sloping Symmetric Truss. |
620 |
Steel/Macro/Truss |
Draws Trapezoid Slopping Asymmetric Truss. |
621 |
Steel/Macro/Truss |
Draws Trapezoid Type 1 Truss. |
622 |
Steel/Macro/Truss |
Draws Trapezoid Type 2 Truss. |
623 |
Steel/Macro/Truss |
Draws Trapezoid Vault Truss. |
624 |
Steel/Macro/Truss |
Draws Triangular Asymmetric Truss. |
625 |
Steel/Macro/Truss |
Draws Triangular Sloping Left Truss. |
626 |
Steel/Macro/Truss |
Draws Triangular Sloping Right Truss. |
627 |
Steel/Macro/Truss |
Draws Triangular Symmetric Truss. |
628 |
Home/Modify |
Line cuts primitive objects such as arcs to another line or arc. |
Facade/Modify |
Concrete/Modify |
Steel/Modify |
Drawings/Modify |
629 |
Trims column edges with an axis or beam. |
630 |
Home/Roof/Roof |
Trims entities with roofs. |
Tools/Tools |
631 |
Home/Wall/Wall |
Trims/extends walls. |
632 |
Draws a trimmer. |
633 |
Steel/Macro |
Draws Custom Truss. |
634 |
Creates a truss connection. |
635 |
Draws tube. |
636 |
Creates a tube base plate connection. |
637 |
Tools/Edit |
Undo. |
638 |
Creates an unstiffened seated connection. |
639 |
Updates linked layout blocks. |
640 |
Update library elevation. |
641 |
Updates 3D railing. |
Rendering/Railing/Railing |
642 |
Use distance. |
643 |
Use dio as reference. |
644 |
Drawings/Hatch |
Draws user defined hatch. |
645 |
Draws user defined tube. |
646 |
Home/Roof |
Draws vault. |
647 |
Steel/Macro/Truss |
Draws Vault Truss. |
648 |
Home/Roof/Vault |
Opens vault settings. |
649 |
Creates a vertical workplane. |
650 |
View/View |
Opens view settings. |
651 |
View/Window |
Display view configuration options. |
652 |
Home/Wall |
Draws wall. |
Modify/Wall |
653 |
Sets wall based. |
654 |
Home/Wall/Wall |
Opens wall settings. |
655 |
Import .obj files. |
656 |
Exports to OBJ file format. |
657 |
Creates a welded box/tube connection. |
658 |
Creates Welded Connection. |
659 |
Creates a welded flange plate connection. |
660 |
Creates a welded web connection. |
661 |
Creates a wind connection. |
662 |
Coordinate Box |
Enters the X coordinate box. X coordinate is entered. |
663 |
Coordinate Box |
Enters the Y coordinate box. Y coordinate is entered. |
664 |
Home/Zone |
Draws zone. |
665 |
Home/Zone |
Draws zone edge. |
666 |
Home/Zone |
Draws zone hole. |
667 |
Home/Zone |
Draws zone list. |
668 |
Home/Zone/Zone Edge |
Opens zone edge settings. |
669 |
Home/Zone/Zone Hole |
Opens zone hole settings. |
670 |
Home/Zone/Zone List |
Opens zone list settings. |
671 |
Home/Zone/Zone |
Opens zone settings. |
672 |
View/Zoom |
Zooms the window. |
673 |
View/Zoom |
Zooms to the extents of the drawings. |
674 |
View/Zoom |
Zoom selection. |
675 |
View/Zoom |
Zoom into a rectangular window. |
676 |
Keyboard |
Zooms in. |
677 |
Keyboard |
Zooms out. |
