The Find Hatch Holes command creates a hatch from two nested areas to the outside area, leaving the inside area as a blank. Automatic hatch feature must be active.
Location of Find Hatch Holes Command
You can access it from the Hatch toolbar that opens when the Bitmap Hatch command is clicked .
Click the Parametric/User Defined/Bitmap Hatch command.
Click the Find Hatch Holes icon from the hatch toolbar .
Click the area you want to hatch.
When creating a hatch on the outer area, the hatch will be created with a blank space on the inside.
Area to be hatched
Activate th find hatch holes
Mouse over the area to be hatched
Creation of the hatch by clicking the left mouse button
