With the Seating Welded Connection command, steel elements are connected to each other by welding.
Location of the Seating Welded Connection Command
From the connection menu, click on the Welded Connection icon.
Click the elements you want to connect sequentially from the 3D perspective view.
Press the right mouse button to finish the selection.
The connection settings dialog will open.
You can edit the settings in this dialog.
Location of the Welded Connection Dialog
General Tab
Form
A selection is made for the shape and a value is entered in the carving gap. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Welds Tab
Welds
Schematic drawing
Preview
Design Data Tab
