With the Single Angle Connection command, column-beam connection is defined.
Location of the Single Angle Connection Command
From the connection menu, click the Single Angle Connection icon.
The single angle connection settings dialog will open.
Location of the Single Angle Connection Settings Dialog
Type and Placement Tab
Connection to support
Bolted or welded connection types are selected for the support connection. |
Connection to beam
Bolted or welded connection types are selected for the beam connection. |
Plates
It is chosen whether the plate will be on the left or right of the beam body. |
Orientation
One of the angled or straight options is chosen for the connection orientation. |
Placement
Placement values are entered. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Connection and placement values are shown on the schematic drawing. |
Preview
Angle Tab
Define plate geometry
If the option is selected, it is determined by entering the angle values. The values to be entered are shown in the schematic drawing. |
Use section
By selecting the option, one of the ready-made L profiles is selected from the list as an angle bracket. By clicking on the load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list. |
Length
Angle length value is entered. |
Schematic drawing
Preview
Top Notch Tab
Notch
If the option is selected, notching is done according to the entered values. The values to be entered are shown in the schematic drawing. |
Left flange cut
If the option is selected, left flange cutting is made according to the entered values. The values to be entered are shown in the schematic drawing. |
Right flange cut
If the option is selected, right flange cutting is made according to the entered values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Bottom Notch Tab
Notch
Left flange cut
Right flange cut
Schematic drawing
Preview
Support Bolts Tab
Horizontal arrangement
Horizontal arrangement settings (number of horizontal bolt columns, distance values ..) of support bolts are entered. The values to be entered are shown in the schematic drawing. |
Group 1
Support bolts settings (number of lines, distance values ..) are entered. The values to be entered are shown in the schematic drawing. |
Bolt properties
Schematic drawing
Preview
Beam Bolts Tab
Horizontal arrangement settings (number of horizontal bolt columns, distance values ..) of beam bolts are entered. The values to be entered are shown in the schematic drawing. |
Group 1
Beam bolts settings (number of lines, distance values ..) are entered. The values to be entered are shown in the schematic drawing. |
Bolt properties
The Hole and Bolt Parameters dialog is opened by clicking on the Bolt properties button . The bolt properties are set in this dialog. |
Schematic drawing
Preview
There is a preview of the combination. The selection made and the entered values can be followed simultaneously in the preview. |
Weldings Tab
Welds
Weld electrode The strengths of the welding electrodes are defined in the design inputs. The strength of the main element in the weld joint is controlled under the condition that it has less strength than the weld strength. If necessary, click the list and define "Create New…". To create the welding electrode, give the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New". Welding geometry is determined automatically by the program. These properties can be changed to easily determine the connection properties. Geometry features are in accordance with industry standards and in the form specified in AISC. Welding geometry is determined automatically by the program. These properties can be changed to easily determine the connection properties. Geometry features are in accordance with industry standards and in the form specified in AISC. |
Schematic drawing
Connection and source values are shown on the schematic drawing. |
Preview
Design Data Tab
