Messages in application limits and R coefficient controls and their possible solutions are listed under this heading.
Messages
Shearwall should be used for A12. -
Shearwall should be used for A13. -
Shearwall should be used for A14. -
Shearwall should be used for A15. -
Shearwall should be used for A21. -
Shearwall should be used for A22. -
Shearwall should be used for A23. -
A24 is selected. Shearwalls should be used. -
There are shearwalls. A11 cannot be selected -
Shearwalls with coupling beam is not found for A12 -
Shearwalls with coupling beam is not found for A14 -
A31 can be used in buildings with DTS = 3 or 4 -
A31 can be used in buildings with DTS = 3 or 4. -
The condition ∑Mdev / M0> = 0.75 at mixed ductility level could not be met. -
For DTS = 3, Mdev / Mo> = 0.75 must be provided. -
For DTS = 4, Mdev / Mo> = 0.75 must be provided. -
For DTS = 1, Mdev> = 0.75Mo must be provided. -
For DTS = 1a, Mdev> = 0.75Mo must be provided. -
For DTS = 2, Mdev> = 0.75Mo must be provided. -
For DTS = 2a, Mdev> = 0.75Mo must be provided. -
For DTS = 3a, Mdev> = 0.75Mo must be provided. -
For DTS = 4a, Mdev> = 0.75Mo must be provided. -
For A33 ∑Mdev / Mo> = 0.75. -
For A32 ∑Mdev / Mo> = 0.75. -
It cannot be used with high ductility level. -
Systems with limited ductility level cannot be used for DTS 1a -
Systems with limited ductility level cannot be used for DTS 2a -
Systems with limited ductility level cannot be used for DTS 3a -
Systems with limited ductility level cannot be used for DTS 4a -
Systems with limited ductility level cannot be used for DTS 1a, 2a, 3a, 4a -
For A11, (BYS)> = 3 condition is not met. -
For A12, (BYS)> = 2 condition is not met. -
For A13, (BYS)> = 2 condition is not met -
For A14, the (BYS)> = 2 condition is not met. -
For A15, the (BYS)> = 2 condition is not met. -
For A21, (BYS)> = 4 condition is not met -
For A22 (BYS)> = 4 condition is not met. -
For A23, (BYS)> = 6 condition is not met. -
For A24, (BYS)> = 6 condition is not met. -
For A31 (BYS)> = 7 condition is not met. -
For A32, (BYS)> = 6 condition is not met. -
For A33, (BYS)> = 6 condition is not met. -
Beamless (mushroom) floor systems should contain shear walls. -
Beamless floor systems should be analyzed with a semi-rigid diaphragm. -
Analyze by choosing the "semi-rigid diaphragm" modeling. -
Select "Use seismic combinations for slab design". -
Bond beam (Hollow) curtain adherence degree is not provided. -
Rigid basement condition is not provided. -
∑Mdev / Mo <0.75 could not be achieved. Solve again with R = 6 -
∑Mdev / Mo <0.75 could not be achieved. Solve again with R = 7. -
0.40 <∑Mdev / Mo could not be achieved. DMS> = 3 could not be achieved. -
Instead of R (4/5) R should be taken. -
R = R should be taken. -
Could not provide >Mdev> = Mo / 6 for curtains. -
Could not provide ∑Mdev> = Mo / 3 for curtains.
