Editing the Selection in Planar Texture Mapper
With the planar texture mapper command, the continuity of the material assigned to the surfaces of different objects such as walls, columns, beams on the same facade can be ensured.
With the Edit selection feature, new objects are added or removed from the selection, previously selected for planar texture mapper.
Location of Edit Selection Feature
You can access the edit selection feature from the projection parameters dialog that opens when you double-click on the defined planar texture overlay projection .
Before changing the selection
Available selected surfaces
Adding new surfaces to the selection
After adding new surfaces
