With the Secondary Steel Beam command, the secondary beams of the steel design are created. The secondary steel beam is the beam elements drawn between steel beams. In the settings dialog that appears after clicking the selected two beams, parameters such as the number of secondary beams, layout, connection properties, etc. are set.
Location of Secondary Steel Beam Command
Click the Secondary Beam icon from the ribbon menu .
The steel beam toolbar will be opened.
Choose the first of the steel beams that will form between the secondary steel beams.
Once you have selected your second steel beam, the secondary beam settings dialog will open.
After making the settings in the dialog, click the OK button.
Secondary steel beams will be formed.
The area where the secondary beam will be created
Choosing the first of the steel beams that will be formed between the secondary beams
Choosing the second steel beam that will be formed between the secondary beams
Making the settings
Formation of secondary beams
