Steel brace axial force strength not satisfied.
For example,
SBR001 BASE STORY Axial force strength not satisfied.
In steel brace design, the design ratio under axial force, tension force, and compression force, buckling limit states are considered according to CYTHYE 2016 (GKT & YDKT), AISC 360-16 (ASD & LRFD) or EN 1993-1-1 codes.
  • The design ratio value should be less than 1.00.
Possible Solutions:
  • Brace length can be reduced. If the element length is reduced, the axial compressive strength increases.
  • Steel element cross-section can be enlarged.
