Defining a Multi Stiffener Plate (Horizontal) Connection
With the Multi Stiffener Plate (Horizontal) command, horizontal stiffener plates are created as many as the count given to any selected steel column or steel beam element.
Location of the Multi Stiffener Plate (Horizontal) Command
  • From the Connection menu, click on theMulti Stiffener Plate (Horizontal) Connection icon.
  • From the Connection menu, click on the Multi Stiffener Plate (Horizontal) Connection icon.
  • The multi stiffener plate (horizontal) connection settings dialog will open.
Location of the Multi Stiffener Plate (Horizontal) Settings Dialog
General Tab
Stiffeners
The number and properties of the stiffeners are determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Side
Stiffners are made for the placement of the side.
If the back stiffener plate is marked, for example I profiles, plates are formed on both sides. If not marked, a plate is created on one side.
Schematic drawing
Preview
Chamfers Tab
Chamfer (c1)
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
The strengths of the welding electrodes are defined in the design inputs. The strength of the main element in the weld connection is controlled under the condition that it has less strength than the weld strength.
To create the welding electrode, provide the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New".
Schematic drawing
Preview
Welds
Weld electrode
Schematic drawing
Preview
Design Data Tab
