Create Steel Drawings
Single element, assembly, application and plan, column anchorage etc. of the project whose Analysis+Design is done. Create steel drawings.
Create Steel Drawings.cde
  • Architectural objects should be deleted when creating steel drawings.
  • Turn off the Wall layer from the layer list.
  • Close the layer list by pressing the Esc key on the keyboard.
  • Select all elements from the perspective view with the Select All command.
  • Remove the pool from the selection by clicking on the pool with the left mouse button.
  • Open all closed layers from the layer list .
  • Close the layer list by pressing the Esc key on the keyboard .
  • Click on the Invert Selection command.
  • Architectural objects will be selected.
  • Delete architectural objects by pressing the Delete key on the keyboard .
  • Open the STORTY 1 CEILING page.
  • Open all closed layers from the layer list.
  • Click the Drawings tab in the Ribbon menu.
  • Open the Steel drawing list from the Create Drawing heading.
  • Click the Steel Drawings command.
  • The Steel Drawings Dialog will open.
  • Click the Settings button.
  • Check the steel drawing settings from the Steel Drawing Settings dialog that opens .
  • Click the View tab.
  • Enter 30 as the rotation on X axis line and 230 as the rotation on Y axis line.
  • Select Single Part Drawings from the Steel Drawings Dialog and click the Generate button.
  • Single Part Drawings will be created.
  • Click on Steel Assembly Drawings from the list of Steel drawings .
  • Assembly Drawings will be created.
  • Click on the Column Anchorage Drawings command from the Steel drawing list.
  • Column Anchor Drawings will be created.
  • Click on the Roof Plan Drawings command from the Steel drawing list .
  • Roof Plan Drawings will be created.
  • Click on the 3D Isometric View Drawings command from the steel drawing list.
  • 3D Isometric View Drawings will be created.
  • Click on the General Construction Drawings w/ Single Parts and Assembly command from the Steel drawing list .
  • All steel drawings will be created on a single sheet.
Next Tutorial
Tutorial Videos
