Get Settings from Object/Set Settings to Object
In cases where the setting of an object is desired to be used in another object of the same type, the settings of the object are copied with the "Get Entity Settings" command, and they are given to another object with the "Set Entity Settings" command.
Usage steps:
  • Click the Get Entity Settings command in the Modify section under the Drawings menu.
  • Click the object whose settings you want to copy.
  • Click the Set Entity Settings command.
  • Click the object you want the setting to be pasted on.
