Defining a Haunch Connection
With the Haunch Connection command, column-beam connection is defined.
Location of the Haunch Connection Command
  • From the Connection menu, click the Haunch icon.
  • The haunch connection settings dialog will open.
Location of the Haunch Connection Settings Dialog
Type and End Plates Tab
Type
For the connection, one of the bolted or welded connection types is selected.
End plate
The end plate is determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Bolt plates
Bolt plates are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Brackets Tab
Upper bracket
It is determined by entering the values ​​for the upper bracket. The values ​​to be entered are shown in the schematic drawing.
Under bracket
It is determined by entering the values ​​for the under bracket. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Bolts Tab
Horizontal arrangement
Group 1
Group 2
Group 3
Bolt properties
Schematic drawing
Connection and bolt arrangement values ​​are shown on the schematic drawing.
Preview
Stiffeners Tab
Column stiffeners
Column stiffeners are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Beam stiffeners
Beam stiffeners are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Extra Plates Tab
Diagonal plate
The diagonal plate is determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Web doubler plate
If the column body thickness is insufficient, web doubler plates are used to meet the shear effect of the panel area. If the web doubler plate will be made, the option is marked. Web doubler plate is determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Cap plate
Top plate is determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Top plate
The top plate is determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Chamfers Tab
Chamfers
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
There is a preview of the combination. The selection made and the entered values ​​can be followed simultaneously in the preview.
Design Data Tab
