The following ASCE 7-16 Strength-Based Design requirements and parameters are met.
Reduced earthquake loads corresponding to the structural system ductility capacity are automatically determined for the projected performance target.
Linear earthquake calculation of the structure is made automatically under reduced seismic loads. In cases specified by the regulation, the reduced internal forces of the elements obtained from these calculations are automatically increased with the overstrength factor, Ωo.
Element strength demands are automatically compared with the determined internal force capacities.
The story drifts obtained from the seismic calculation are compared with the limits specified by the regulation, and automatically determined results are reported.
It is automatically indicated by reports that the strength demands and story drifts are below the specified limits; if there are insufficiencies, the user is warned.
Design Coefficients and Factors for Seismic Force-Resisting System per ASCE 7-16 §11.2 -
Conditions Regarding Ductility Levels of Structural Systems per ASCE 7-16 §11.2 -
Application of Overstrength Factor per ASCE 7-16 §12.2.1 -
Application of Deflection Amplification Factor per ASCE 7-16 §11.2.1 -
Redundancy Factor per ASCE 7-16 §12.3.4 -
Reduced Design Response Spectrum for Modal Analysis per ASCE 7-16 §12.9.1.2 -
Seismic Load Effects and Combination per ASCE 7-16 §12.4 -
Load Combination and Strength Design per ASCE 7-16 §2.3 -
Analysis Procedure Selection per ASCE 7-16 §12.6 -
Modeling Criteria per ASCE 7-16 §12.7 -
Modeling of Masses per ASCE 7-16 with ideCAD -
Effective Section Stiffness per ASCE 7-16 §12.7.3 -
Equivalent Lateral Force Method (ELF) per ASCE 7-16 §12.8 -
Inherent Torsion per ASCE 7-16 with ideCAD -
Accidental Torsion per ASCE 7-16 §12.8.4.2 -
P-Delta Effects per ASCE 7-16 with ideCAD -
Linear Dynamic Analysis Methods per ASCE 7-16 with ideCAD -
Modal Response Spectrum Analysis per ASCE 7-16 §12.9.1 -
Scaling Design Values of Combined Response per ASCE 7-16 §12.9.1.4 -
Diaphragms, Chords, and Collectors per ASCE 7-17 with ideCAD -
Determination and Limitation of Story Drifts per ASCE 7-16 §12.12 -
Foundation Design per ASCE 7-16 §12.13
