With the Circular Column to Rectangular command, created circular column are transformed into rectangular column.
Location of Circular Column to Rectangular Command
Click the Circular Column to Rectangular icon.
Select the circular column to be transformed into rectangular column.
Click the right mouse button.
The circular column will be transformed to rectangular column automatically without corrupting the existing data input.
Circular column to be transformed into rectangular column
Choosing the column
Transforming circular column into rectangular column
During the transformation, the angle used when creating the circular column is taken as the reference for the angle of the rectangular column.
