Longitudinal Reinforcement Detailing (SwRD)
  • Longitudinal reinforcement detailing is applied automatically in accordance with Codes.
  • Longitudinal reinforcement detailing is applied according to Codes in special structural walls.
International Design Codes
ACI 318-19 : Longitudinal Reinforcement (SwRD) per ACI 318-19 with ideCAD
TSC 2018 : Shearwall Web Reinforcement Detailing
Notation in ACI 318-19
Ast = total area of nonprestressed longitudinal reinforcement, in2
hsx = story height for story x, in.
ϕ = strength reduction factor
