Analysis is done automatically according to finite element method.
Required strength is designed to analyse with Load Combinations
International Design Codes
ACI 318-19 : One-Way Slab Required Strength per ACI 318-19 with ideCAD
TSC 2018 :
Symbols in ACI 318-19
Required strength is designed to analyse with load factors and combinations. Analysis is done automatically according to finite element method. Rigid and semi-rigid diaphram conditions should be choosen by user according to Codes.
