I started with a white background template. How can I activate the black background template colors.
The following steps are followed to open and use the project with black background template colors.
  • When you click the ideCAD icon, click the New command from the list that opens .
  • In the new project dialog that opens, select start using new project wizard and click the open button.
  • The Country & General dialog will open. After selecting country and unit, choose the Black Background option for the project background color from the project colors section. Click on the next button.
  • Select the codes to use.
  • Select the bolts & fasteners.
  • Click on the Finish button.
  • A new project file with the black background will open.
  • When you click the ideCAD icon, click the Open command from the drop-down list .
  • The load project dialog will open.
  • Activate by checking the Apply current pen and color option under the preview window in the dialog .
  • Select your project and click the Open button.
  • When your project is opened, the pen and color settings will be changed with the template settings you selected.
