Divide-Combine All Intersections
With the Divide-Combine All Intersections command, the purlins are split in main beams, columns and/or trusses or split purlins are combine.
Location of Divide-Combine All Intersections Command
You can access it under the Ribbon menu Steel tab, Steel heading.
  • Click the divide-combine all intersections icon.
  • Select the purlins you want to split.
  • The ideCAD will automatically split all your purlins.
  • You can selectively combine previously divided purlins.
  • You can set the distance between the purlins between the dividing process in the division on intersections section in the extensions tab of the Purlin Settings dialog.
Purlins before divide-combine all intersections command
Choosing the purlins to divide
Purlins after divide-combine all intersections command
