Defining a Column-Foundation Connection (Stiffened Baseplate)
With the Column-Foundation Connection (Stiffened Baseplate) command, column-foundation connection is defined.
Location of the Column-Foundation Connection (Stiffened Baseplate) Command
  • From the Connection menu, click on theColumn-Foundation Connection (Stiffened Baseplate) icon.
  • From the Connection menu, click on the Column-Foundation Connection (Stiffened Baseplate) icon.
  • The column-foundation connection (stiffened baseplate) settings dialog will open.
Location of the Column-Foundation Connection (Stiffened Baseplate) Settings Dialog
Stiffeners Tab
Stiffening type for primary direction
Stiffening type in the primary direction is selected from the options.
Stiffening type for secondary direction
Stiffening type in the secondary direction is selected from the options.
Preview
Plates and Grout Tab
Main plate
The dimensions of the main plate are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Fitting plate 1
Fitting plate 1 dimensions are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Fitting plate 2
Fitting plate 2 dimensions are determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Grout
It is determined by entering values ​​for grout. The values ​​to be entered are shown in the schematic drawing.
Cast plate
Cast plate dimensions are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Primary Stiffeners Tab
Stiffening plate
Stiffening plate dimensions are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Bent plate (geometry)
The bent plate geometry is determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Bent plate (section)
The bent plate section is determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Secondary Stiffeners Tab
Edge and center plates
Edge and center plate dimensions are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
The bent plate cross section is determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Chamfers Tab
Chamfers
Schematic drawing
Preview
Anchorage Tab
Primary direction
It is determined by entering the number of anchors in the primary direction and the distance values. The values ​​to be entered are shown in the schematic drawing.
Secondary direction
It is determined by entering the number of anchors in the secondary direction and the distance values. The values ​​to be entered are shown in the schematic drawing.
Anchors
Anchor type is selected from the list. Anchor dimensions are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Bolt properties
Schematic drawing
Preview
Shear Assembly Tab
Shear key
One of the ready-made profiles is selected from the list as a shear key. By clicking on the load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list.
Shear key length
The shear key length is entered. The values ​​to be entered are shown in the schematic drawing.
Washer plate
The washer plate dimensions are determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
Design Data Tab
In the Design Data tab, you can define the plate material and select the stress distribution type for the base plate, which determines the method used in the connection design.
You can choose between the uniform and triangular methods as the stress distribution approach for the base plate. To make a selection, click once on the checkbox next to the method you want to use. If the box is filled in blue, it means the option is selected.
