Part 47. Examine the Analysis Model
In this tutorial, examine the analysis model.
1. Use the Analysis+Design (F9) command.
2. Use the Analysis Model command.
3. Use the 1.4G+1.6Q command from Deformation heading.
4. Select the Modal E1 from Case/combination list.
5. Click the Animate command.
6. Select the G'+Q'+Ex-0.3Ey+0.3Ez from Case/combination list.
7. Use the Moment 3-3 command from Frame Results heading.
8. Use the Moment 3-3 command from Purlin heading.
9. Use the Shell Results command from Shell Elements heading.
10. Select the Slab Results and M11 from the Component list.
11. Select the 1.4G+1.6Q from Case/combination list.
12. Use the AS1 Under command from Shell Elements heading.
13. Use the Concrete Insufficient Rebar Area command.
