Application Plan Drawings
The Application Plan Drawings command is used to prepare the application plan drawings.
Location of the Application Plan Drawings Command
  • Click on the Application Plan Drawings icon.
  • Application plan drawings will be created.
  • Before creating the drawings, you can access the Steel Drawing Settings dialog by clicking the settings button from the steel drawings dialog . From this dialog, layout settings, scales, fonts, etc. You can access parameters related to steel drawings.
Sample application plan drawing
