Shear Wall Shear Design.
  • Wall design shear strengths are calculated automatically.
  • Wall required shear strengths are calculated automatically.
International Design Codes
ACI 318-19 : Shear Wall Shear Design per ACI 318-19 with ideCAD
TSC 2018 : Design Shear Forces for Walls Wall Design Shear Strength Calculation
Notation in ACI 318-19
Acv = gross area of concrete section bounded by web thickness and length of section in the direction of shear force considered in the case of walls, and gross area of concrete section in the case of diaphrams. Gross area is total area of defined section minus area of any openings, in.2
Acw = area of concrete section of an individual pier, horizontal wall segment, or coupling beam resisting shear, in2.
D = dead load
E = earthquake load
hwcs = height of entire structural wall above the critical section for flexural and axial loads, in.
L = live load
Lr = roof live load
Mpr = probable flexural strength of members, with or without axial load, determined using the properties of the member at joint faces assuming a tensile stress in the longitudinal bars of at leasts 1.25fy and a strength reduction factor ϕ of 1.0, in.-lb
ns = number of stories above the critical section
R = rain load
S = snow load
Nu = factored axial force normal to cross section occurring simultaneously with Vu or Tu; to be taken as positive for compression and negative for tension, lb
positive for compression and negative lb
Ve = design shear force for load combinations including earthquake effects, lb
wu = factored load per unit length of beam or one-way slab, lb/in.
W = wind load
αc = coefficient defining the relative contribution of concrete strength to nominal wall shear strength
ϕ = strength reduction factor
Ωv = overstrength factor equal to the ratio of Mpr/Mu at the wall critical section
ωv = factor to account for dynamic shear amplification
ρl = ratio of area of distributed longitudinal reinforcement to gross concrete area perpendicular to that reinforcement
ρt = ratio of area of distributed transverse reinforcement to gross concrete area perpendicular to that reinforcement
