With the Simple Base Plate command, steel column-foundation connections are defined.
Location of Simple Base Plate Command
Click the Simple Base Plate icon from the Connection menu.
Click the column from the 3D perspective view.
Location of the Simple Base Plate Connection Dialog
Select the combination and click the right mouse button. Click the Properties line from the right click menu that opens.
Plates and Grout Tab
Main plate
The main plate is determined by entering the value. The values to be entered are shown in the schematic drawing. |
Fitting plate 1/2
Fitting plates are determined by entering the value. The values to be entered are shown in the schematic drawing. |
Grout The value is entered for grout. The values to be entered are shown in the schematic drawing. |
Cast plate
The cast plate is determined by entering the value. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Anchorage Tab
Primary direction
It is determined by entering the number of anchorage to be located in the primary direction and the distance values. The values to be entered are shown in the schematic drawing. |
Secondary direction It is determined by entering the number of anchorage to be located in the secondary direction and the distance values. The values to be entered are shown in the schematic drawing. |
Anchors
Anchor type is selected from the list. Anchor dimensions are determined by entering values. The values to be entered are shown in the schematic drawing. |
Bolt properties
Schematic drawing
Preview
Shear Assembly Tab
Shear key
One of the ready-made profiles is selected from the list as a shear key. By clicking on the load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list. |
Shear key length The shear key length is entered. The values to be entered are shown in the schematic drawing. |
Washer plate
The washer plate dimensions are determined by entering the values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Welds Tab
Welds
Schematic drawing
Preview
Design Data Tab
