The dormer dio command defines the dormer window in the dormer. To define an dormer window, first the dormer is defined on the roof and then the window is defined on the dormer.
Location of Dormer Dio Command
You can access it under the heading of the Ribbon menu, Home tab, Roof .
Click the Dormer Dio icon from the dormer toolbar.
At this stage , click the Settings icon in the dormer toolbar, open the Dormer Settings dialog and select the window you want to use as the dormer window.
In the window settings, give the window size and click the OK button to close the window settings.
Place the cursor on the dormer and select the dormer by clicking the left mouse button.
At this stage, you can enter a value in the Distance line in the dormer toolbar .
This value determines the position of the window on the dormer.
Press the right mouse button. Dormer window will be formed
Dormer before the window is placed
Entering the settings while in the dormer dio command, selecting the window type to be placed
Adjusting the layout settings
Selecting the dormer to place the dormer window
The formation of the dormer window
