In the ideCAD Architectural Program, they are objects that are formed only in the 2D plan view and show the opening of the wing. It is drawn in the 2D plan window and appears in the plan in the ideCAD Architecture program. The opening angle of the 3D wing does not affect the angle of the opening arc.
To create an opening spring;
Create a 2D plan.
Click the Line Drawing / Opening Spring .
Determine the start and end points of the broadcast in the plan.
The opening arc will be formed.
To change the current opening publication;
Place the cursor on the opening arc and click the right mouse button.
Click the properties line in the menu that opens. You can make the necessary changes in the dialog that comes up.
