Concrete Design Result Dialogues
In the concrete design result dialogs, the reinforcement status of the concrete elements, the internal force values ​​and the seismic code checks, as well as the inadequacy conditions are shown.
With ideCAD Structural, concrete structures are analyzed and designed with the DGT approach. Concrete design is made by applying TBDY 2018 and TS 500 conditions. As a result of the concrete design, the transverse and longitudinal reinforcements calculated in the design of the concrete elements (column, beam, slab, shearwall, foundation, retaining wall, etc.), internal forces calculated as a result of the analysis, increased internal forces related to TBDY, capacity ratios, deflection and crack control results are given in concrete element design result dialogs. Concrete design results, reinforcement layout, reinforcement diameter and reinforcement interval are examined from the concrete element design dialogs and interventions are made when necessary.
Slab Reinforcements
