Creating a Polygonal Sheeting
With the Polygonal Sheeting command, a sheeting element is created on plane which continuous objects are defined in. Sheetings are load transfer elements.
Polygonal Sheeting Command Location
  • Click the Polygonal Sheeting icon.
  • Select the steel element surface to determine the plane on which to create the sheeting on the perspective screen.
  • Select the elements to be sheeting to create a closed area.
  • After the selections are completed, the drawing is completed by clicking the right button of the mouse.
Before creating a polygonal sheeting
Determination of the sheeting plane
Selecting the elements to be defined on the sheeting to form the closed one
After creating a polygonal sheeting
