Concrete design results for the foundation tie modeled with Single and Strip Foundations are shown in the Foundation Tie Reinforcements dialog where the inability to relate to the foundation ties.
Location of Foundation Tie Reinforcements Dialog
After the analysis, you can access it by clicking the Foundation Tie Reinforcements command under the Concrete Design title of the ribbon menu Analysis and Design tab .
ID
It is the name of the foundation tie in the plan. |
B, H
It is the foundation tie dimension, which consists of width and height, respectively. |
Top
It is the number and diameter of assembly rebar. |
Bottom
It is the number and diameter of straight rebar. |
Stirrup
The diameter of the stirrup is the middle zone and the squeezing zone range. |
Body
It is the number and diameter of the body rebar. |
Nk
It represents the column factored axial load. |
Nb
It represents the tie beam axial design strength. |
As (Calc.)
It is the amount of reinforcement area calculated. |
As (Req.)
It is the amount of required longitudinal reinforcement area. |
As (Existing)
It is the amount of available longitudinal reinforcement area. |
As (Rem.)
It is the amount of excess rebar in the section. |
RC The element rebuilds its concrete. The regulation calculations related to concrete and rebars are also made again. In important changes, it may be more appropriate to repeat the structure analysis instead of concrete. |
Ok It saves the changes made and closes the dialog. |
Using the Shift key In this tab, you can select more than one row with the Shift key, enter a value by double-clicking any cell whose value is open to change, and you can make that value apply to all selected rows. |
Using the Ctrl key Ctrl key, on the other hand, selects the lines in between one by one. |
