With the Steel Hand Rail Macro on Arc command, arc steel hand rails are created.
Location of Steel Hand Rail Macro on Arc Command
You can access it under the ribbon menu Steel tab Macro.
Click the steel hand rail macro on arc command.
Create the starting point of the hand rail by clicking with the left mouse button.
Specify the end point and click the left mouse button.
Determine the diameter of the arc by moving the mouse and click the left button.
Your hand rail will be created.
The facade to be formed with arc steel hand rail
Determining the starting point of the hand rail
Determining the end point of the hand rail
Formation of the preview of the arc steel hand rail
Determination of the diameter of the arc steel hand rail
Formation of arc steel hand rail
