Semi-Rigid Diaphragm (Elastic Diaphragm) Behavior
It is the analysis of slabs by dividing them into shell elements and taking into account their deformations.
With Semi-Rigid Diaphragm Behavior;
  • Slabs are divided into shell elements.
  • Since the in-plane effects of the slab are taken into account, it gives more precise results.
  • Story masses are considered as distributed masses along the slabs.
Preferred building types;
  • Structures with plan irregularity and torsional irregularity
  • Structures with slab discontinuity
  • Structures with beamless slab system
  • Structures with rib or cassette slab system
The slab is divided into shell elements and deformations are taken into account.
  • When we compare the rigid diaphragm and semi-rigid diaphragm models, different displacement values ​​are seen in the middle region of the models.
  • In the semi-rigid diaphragm model, the displacement value is 0.163 millimeters.
Taken from ideCAD Finite Element Guidelines from pages 57 to after.
Diaphragm Modeling Selection
To model a Semi-Rigid diaphragm, select the diaphragm modeling method from the Analysis Settings dialog.
Display of Horizontal Loads
Behavior of Structure Under Vertical Loads
Examination of Transitional Storey Structures with Semi-Rigid Diaphragm
Examination of Structures with A2 - A3 Irregularity with Semi-Rigid Diaphragm
Examination of Structures with Beamless Flooring with Semi-Rigid Diaphragm
