Generate Steel Design Reports
Generate TBDY, concrete and steel element reports of the project whose Analysis+Design is done.
Generate Steel Design Reports.cde
  • Click the Analysis+Design (F9) command.
  • Do you want to perform analysis? question will be asked.
  • Click the Yes button.
  • Wait for the analysis to complete in the Analysis Status window.
  • After the analysis is complete, click the OK button to close the window.
  • Open the list of Introduction Informations from the Structure Tree, Results list.
  • Click the Structure General Information line.
  • Structure General Information reports will open in the Report Preview window.
  • Close the Report Preview window.
  • Click on the Ribbon menu Reports tab.
  • Click on the Steel Column Report command from the Steel heading.
  • Steel column reports will be opened in the ide Report.
  • With the Fit height command, the zoom is made according to the page height.
  • Examine steel column reports.
  • Close the ide Report.
  • Click the Steel Purlin Report command in the Steel heading.
  • Steel purlin reports will be opened in the ide Report.
  • With the Fit width command, the zoom is made according to the page width.
  • Examine the steel purlin reports.
  • From the perspective window, right-click the mouse to open the right-click menu.
  • Click the Solid with Edges line.
  • Double-click the left mouse button on one of the column foundation connection.
  • The Stiffened Baseplate Connection dialog will open.
  • Click on the Design Report button.
  • The connection design report dialog will open.
  • Review the steel connection design report.
Next Tutorial
Create Concrete Drawings
