With the Stub command, stubs are defined to steel column.
Location of the Stub Command
Click on the Stub icon from the Connection menu.
Click the column from the 3D perspective view.
The stub settings dialog will open.
Location of the Stub Settings Dialog
Plates Tab
Stub type
One of the stub type is selected from the list. |
Direction
It shows the placement of the stub element relative to the column axis. The direction of the stub on the column changes according to the selected axis. |
Stiffeners
The top and bottom stiffeners are marked and stiffener plates are formed in the column at the level of the element. |
Preview
General and Plates Tab
Seat plate
Seat plate dimensions are determined by entering values. The values to be entered are shown in the schematic drawing. |
Stiffener plates
The dimensions of the stiffener plate are determined by entering the values. The values to be entered are shown in the schematic drawing. |
General
The elevation of the stub is determined. |
Schematic drawing
Preview
Brackets Tab
The values on this tab vary according to the selected stub type. Enter data according to the schematic representation.
Brackets
Bracekt plate dimensions are determined by entering the values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Chamfers Tab
Chamfers
Schematic drawing
Preview
Welds Tab
Welds
The thickness, type and angle values of the welds to be made at the joints are given. The information on whether it will be done on the construction site or not is entered. |
Weld electrode The strengths of the welding electrodes are defined in the design inputs. The strength of the main element in the weld joint is controlled under the condition that it has less strength than the weld strength. If necessary, click the list and define "Create New…". To create the welding electrode, give the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New". Welding geometry is determined automatically by the program. These properties can be changed to easily determine the connection properties. Geometry features are in accordance with industry standards and in the form specified in AISC.
Schematic drawing
Preview
Bolts Tab
This tab appears when the 3rd type, bolted console is selected.
Horizontal arrangement
The horizontal arrangement distance value of the bolts is entered. The values to be entered are shown in the schematic drawing. |
Group 1
Bolt properties
Schematic drawing
Preview
Design Data Tab
