Drawing details such as the opening direction can be given in the lines and plan / view windows. The definitions and joints of the lines are the same and in 2.
To create a line;
Click on the Line Drawing / Line .
After clicking your first point, the Line will begin to form and change shape depending on the mouse. A line will be formed after clicking your second point.
Lines must be connected to the wings with the " Set Case Object Link" command. Otherwise, the line will stay where it is when the wing opens.
To make changes to the existing line;
Click on the line. The line will turn green and the nodes will become active as red boxes.
The cursor shape will change when you hover over the node points. In this case, you can click the nodes and move them.
You can delete lines by pressing the Del / Delete key on the keyboard .
By entering the properties of the lines, you can adjust their placement according to the frame.
