The rectangular bar frame is an object that can be used for various purposes, allowing objects such as wings to be created directly without the need to define a rectangular profile. It is created within the facade (xz plane). It has knots on both ends.
To create a rectangular bar;
Click the Line Drawing / Square Bar . The square bar command will be activated.
Click the starting point of the bar in the drawing area. After clicking the first point, you will see a dialog where you can set the profile properties of the rectangular bar you want to draw.
Make this adjustment and set the second point and click. The bar will be drawn.
To make changes to the existing square bar;
Hover over the existing rectangular bar and click it. The bar will turn green and there will be nodes shown with red boxes at both ends.
You can change the bar by clicking on the nodes with the mouse and moving the mouse.
To change profile and material properties, move the cursor over the relevant bar and click the right mouse button. Make the changes you want in the dialog that comes up.
