The Upload command is used to open dio files .
Click the Upload line from the File menu or the Load icon from the toolbar.
Select the folder containing the dio files from the dialog that opens.
Select the dio file you want and click the Open button.
Not
You can open the last 4 files you have used by clicking on their names in the Recents section. ( Recents section is at the bottom of the File menu.)
We recommend that you copy the windows you created in the ODT program to the windows folder in the Dio folder under the folder where ideCAD Architecture is installed , and the doors to the doors folder. ideCAD Architecture uses the folders and dio files under the Dio folder. By creating new folders in the Dio folder, you can create new categories that you can use in ideCAD Architecture.
