With the Multi Stiffener Plate command, stiffening plates are created as much as the number given to the steel column or steel beam element selected.
Location of the Multi Stiffener Plate Connection Command
From the Connection menu, click the Multi Stiffener Plate Connection icon.
The multi stiffener plate connection settings dialog will open.
Location of the Multi Stiffener Plate Connection Settings Dialog
General Tab
Stiffeners
The number and properties of the stiffeners are determined by entering the values. The values to be entered are shown in the schematic drawing. |
Side
Stiffners are made for the placement of the side. If the back stiffener plate is marked, for example I profiles, plates are formed on both sides. If not marked, a plate is created on one side. |
Schematic drawing
Preview
Chamfers Tab
Chamfer (c1)
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode The strengths of the welding electrodes are defined in the design inputs. The strength of the main element in the weld connection is controlled under the condition that it has less strength than the weld strength. To create the welding electrode, provide the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New". Welding geometry is determined automatically by the program. These properties can be changed to easily determine the connection properties. Geometry features are in accordance with industry standards and in the form specified in AISC. |
Schematic drawing
Preview
Design Data Tab
