Add/Remove Points to Hatch
With the Add Point/Remove Point commands, the hatch boundaries are changed by adding new points to the hatch or removing points.
Location of Add Point Command
After entering the User Defined Hatch command under the Hatch title of the ribbon menu Drawings tab , you can access the Add Point command from the Hatch dialog that opens .
Add Point Usage Steps
  • Click the add point command.
  • Activate the midpoint snap feature.
  • Click with the left mouse button in the middle of the upper hatching edge.
  • A new point will be created.
  • You can add as many new points to your hatch as you want.
Hatch before adding points
Clicking the midpoint of the upper hatch edge
Hatch after adding point
Location of Remove Point Command
After entering the Defined Scan command under the Scan title of the Ribbon menu Drawings tab , you can access the Delete Point command from the Scan dialog that opens .
Remove Point Usage Steps
  • Click on the remove point command.
  • Click with the left mouse button on the midpoint of the upper hatching edge.
  • You can remove any points in your hatch.
Hatch before point remove
Hatch after point remove
Annonation
