In accordance with the EN 1993-1-1 bearing strength method, the load applied to the structure should not exceed the strength of the structure. EN 1993-1-1 accepts that different load combinations have different probabilities of occurrence and different degrees of variability. Load combinations according to Eurocode 3 are given below.
Dead Load Situation: 1.35G
Dead and Live Load Situation: 1.35G + 1.5Q
Dead and Wind Load Situation: 1.35G ± 1.5W
Dead and Wind Load Situation: 1.00G ± 1.5W
Dead, Wind, and Live Load Situation: 1.35G +1.35Q ± 1.5W
Earthquake Load Situation: 1.00G ± 1.00AEd
Dead, Live Load, and Earthquake Situation: 1.00G ± 1.0×0.3Q ± 1.00AEd
Structural Safety
It assumes that there can be situations and probabilities in which the loads can be greater than the expected value. For this reason, different coefficients and load combinations are determined for different loads.
Steel Design per EN 1993-1-1 -
Classification of cross sections per EN 1993-1-1 -
Elastic and Plastic Analysis per EN 1993-1-1 -
Design of Compression Elements per EN 1993-1-1 -
Design of Tension Elements per EN 1993-1-1 -
Flexural Design per EN 1993-1-1 -
Axial Force and Bending Moment Interaction Design per EN 1993-1-1 -
Shear Design per EN 1993-1-1
