With the Zone Hole Settings command, the Settings - Path dialog is accessed. Color and line settings are made.
Location of the Zone Hole Settings Command
You can access it under the ribbon menu Home tab, Zone title.
Settings - Path Dialog
Color Sets the color of the line. When the color box is clicked, the appropriate color is selected from the window that opens. |
Line thickness Line thickness is selected. The appropriate thickness is selected from the drop-down list when the down arrow button next to the box is clicked. The thickness selected here is only valid on the screen. It does not affect drawing printouts. |
Linetype Line type is selected. When the down arrow button next to the box is clicked, the appropriate line type is selected from the drop-down list. |
