Annotations Objects Tab
Many dimension commands such as outer, inner, free and level dimension are designed for dimensioning the project. Properties of the dimensions, such as display style, size, and color, can be changed in the dimension settings dialogs.
Free Dimension Settings
Text Section
The font height of the dimensions is entered.
The distance of the dimension text from the objects is entered.
The distance of the dimension text to the dimension line is entered.
The position of the dimension text relative to the dimension line is selected.
When the button is clicked, the "Font Settings" dialog appears. Font of information text can be set here.
Distances Section
Line displacement
The distance from the dimension lines to each other is determined.
The size of the cross separators is entered in the dimension lines.
Upper marker size of the dimension line is entered.
The bottom marker size of the dimension line is entered.
How long the dimension line will continue after the left and right end reference points is entered.
The distance of the dimension line from the curved objects taken as reference by the bottom separator is entered.
Dimension style
Display type of dimension lines is selected.
Colors Section
Sets the color of the dimension lines. When the color box is clicked, the appropriate color is selected from the window that opens.
Sets the color of the measure separators. When the color box is clicked, the appropriate color is selected from the window that opens.
Value scale
The actual length values ​​written on the dimension line are multiplied with the value written here and the value found at the result of multiplication is used as the measurement value. For example, the dimension line values ​​are 120, 200, 350. If 2 is written to the scale value, the lengths of 120, 200, 250 will be written as 240, 400, 700 in the dimensioning line.
Marker type
One of the two markers types that can be used in dimension is selected.
Dimension Lines Section
Total
It gives the total length of all lines.
Outer Dimension Settings
Text section
The font height of the dimension is entered.
Distances section
Line displacement
Upper bracket size of the dimension line is entered.
Dimension style
Colors Section
Sets the color of the dimension marker. When the color box is clicked, the appropriate color is selected from the window that opens.
Value scale
The actual length values ​​written on the dimensioning line are multiplied with the value written here and the value found at the result of multiplication is used as the measurement value. For example, the dimension line values ​​are 120, 200, 350. If 2 is written to the scale value, the lengths of 120, 200, 250 will be written as 240, 400, 700 in the dimensioning line.
Offset
If the "Connected to objectt" option is selected, the dimensioning line is drawn from the selected objects as far as the entered offset distance value. If the box is not checked, dimensioning is drawn on the line determined by clicking two points with the mouse in the drawing area.
Marker type
One of the two marker types that can be used in dimensioning is selected.
Dimension lines section
Total
Axis
It gives the dimensions of the axes corresponding to the dimensioning line.
Walls/Beams/Shearwalls
It shows the lengths of each wall/beam/shearwall part in the selected line.
Columns
Shows the lengths of the columns selected on the outer dimensioning line
Doors / Windows
Shows the distances between the middle points of the doors / windows placed on the walls on the selected line.
Extended properties section
Use columns on axis dimension
In external dimensioning, the axes are dimensioned and also the columns are dimensioned.
Use inner intersections
In the outer dimension, the wall-wall on the wall / beam / shearwall is measured, shearwall-shearwall or shearwall-beam on the shearwall, beam-beam or shearwall-shearwall intersections on the beam.
Write door/window height
On the dimensioning line, the door / window height value is also written on the door / window width measurement value.
Inner Dimension Settings
Text Section
Distances Section
Line displacement
Colors Section
Sets the color of the markers. When the color box is clicked, the appropriate color is selected from the window that opens.
Value scale
Marker type
Dimension lines - Total
On the dimension line, the door / window height value is also written on the door / window width measurement value.
Use plaster
It shows the wall by taking the width from wall plaster to wall plaster in the inner dimension line. If not marked, the wall will measure the width of the wall.
Label Settings
Drawing color
 Sets the color of the label lines. When the color box is clicked, the appropriate color is selected from the window that opens.
Text color
Sets the color of label posts. When the color box is clicked, the appropriate color is selected from the window that opens.
Text height
Label height is entered.
Text angle
Label text angle is entered.
Label tip
One of the 4 display types given for the label line end is selected.
Label
Label line end dimensions are determined by entering values ​​in the X and Y boxes.
Level Dimension Settings
Label Section
The size of the elevation icon is entered.
The angle of the elevation symbol is entered. The icon will rotate according to the entered value.
Colors Section
Sets the color of the elevation icon. When the color box is clicked, the appropriate color is selected from the window that opens.
One of the 5 display types given for elevation dimension is selected.
Text Section
By entering the values ​​entered in Text dx, and Text dy boxes, the position of the text is adjusted according to the label.
The height of the elevation lettering is adjusted.
One of the 4 display types given for elevation text is selected.
Draw architecturalslab level on zones
Slab height is shown as elevation height.
Draw structural slab level on zones
When the elevation is placed on the floor, the elevation value is shown by adding the height of the floor and the floor elevation.
Global elevation
The elevation dimension value is given according to the building floor. If unchecked, the value is given according to the floor base.
Elevation Dimension Settings
Text location
The position of the elevation text relative to the icon is selected.
Direction
The direction of the elevation arrow is selected.
Size
The size of the elevation arrow is selected.
Fill
Display type of elevation arrow is selected.
Text section
Text dx/font dy
By entering the values ​​entered in the Text dx, Text dx and Text dy boxes, the location of the text is adjusted according to the elevation symbol.
Text height
The height of the elevation text is entered.
One of the 2 display types given for elevation text is selected.
Dimensions Section
The height of the elevation arrow is entered.
Line length on the left side of the elevation icon is entered.
The length of the line on the right side of the elevation icon is entered.
Colors section
Adjusts the color of elevation text. When the color box is clicked, the appropriate color is selected from the window that opens.
Adjusts the color of the elevation lines. When the color box is clicked, the appropriate color is selected from the window that opens.
Sets the color of the elevation arrow. When the color box is clicked, the appropriate color is selected from the window that opens.
Angle Dimension Settings
Text Section
Arrow head scale factor
The factor determining the size of the dimension arrow is given.
Arrow head
 One of the 12 display types given for the angle dimension arrow is selected.
Colors Section
Sets the color of the dimension arrows. When the color box is clicked, the appropriate color is selected from the window that opens.
Text direction
The position of the dimension text is set.
Radial Dimension Settings
Text Section
Prefix
Determines the naming to be used in diameter dimensioning.
Calculation
It is determined whether the diameter will be measured according to the radius or according to the diameter.
Arrow head
One of the 12 display types given for the radius dimension arrow head is selected.
Colors Section
