Beam Reinforcement Limits per ACI 318-19 with ideCAD
How does ideCAD control beam reinforcement limits according to ACI 318-19?
  • Longitudinal and Transverse reinforcement limits are controlled automatically.
Notation
Acp = area enclosed by outside perimeter of concrete cross section, in.2
Al = total area of longitudinal reinforcement to resist torsion, in.2
Al,min = minimum area of longitudinal reinforcement to resist torsion, in.2
As,min = minimum area of flexural reinforcement, in.2
At = area of one leg of a closed stirrup, hoop, or tie resisting torsion within spacing s, in.2
Av,min = minimum area of shear reinforcement within spacing s, in.2
Tcr = cracking torsional moment, in.-lb
Tth = threshold torsional moment, in.-lb
ϕ = strength reduction factor
ρ = ratio of As to bd
:check_mark:
Download ideCAD for Beam Reinforcement according to ACI 318-19
Minimum flexural reinforcement
According to ACI 9.6.1.2, a minimum area of flexural reinforcement, As,min is equal to the greater of the following relations;
According to ACI 9.6.1.3, if As provided at every section is greater than one-third of As calculated by analysis, As,min need not be satisfied.
Minimum shear reinforcement
If shear reinforcement is required, minimum shear reinforcement area, Av,min, should be considered in accordance with ACI Table 9.6.3.4.
For nonprestressed beams, minimum shear reinforcement area, Av,min, should be provided in all sections where Vu >ϕλ √fc‘ bwd, except for the cases given in ACI Table 9.6.3.1. For the cases given in ACI Table 9.6.3.1., Av,min, should be provided where Vu>ϕVc
In other words, if ϕλ√fc‘(bwd) < Vu < [ Vc + 8√fc‘(bwd) ], the minimum shear reinforcement area, Av,min, is calculated given below.
Minimum torsional reinforcement
  • If Tu < ϕTth, torsional effects are ignored.
  • If ϕTcr > Tu ≥ ϕTth, only minimum torsional reinforcement needs to be provided given below;
Minimum transverse reinforcement (Av + 2At)min / s
the minimum area of longitudinal reinforcement Al,min
Reinforcement Limits for Beams of Earthquake-Resistant Structures
Ordinary moment frames
All the conditions and calculations described above are valid for beams of ordinary moment frames.
Intermediate moment frames
All the conditions and calculations described above are valid for beams of intermediate moment frames.
Special moment frames
All the conditions and calculations described above are valid for beams of special moment frames.
According to ACI 18.6.3.1; Longitudinal reinforcement should be satisfied the conditions given below;
  • Beams should have a minimum of two continuous bars at the top and bottom faces.
  • The reinforcement ratio ρ shall not exceed 0.025 for Grade 60 or S420 reinforcement and 0.02 for Grade 80 reinforcement.
:check_mark:
